AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 08-01-2004, 5:49 PM   #1 (permalink)
rupbert's Avatar
Thanks: Gave 25, Got 19
Getting CD player from RS this weekend, which one?
Choice is:
Cambridge Azure 640c £250
NAD 542 £290
Arcam CD62 £250!
Heard Azure and NAD (similar/good), Arcam has the pedigree...
Budget £400...
Will be using with Sony STR-DB790, no dedicated stereo amp; will use the CDP's DAC though with IXOS interconnect.
Need to make a decision by Saturday peeps!
ta
rupbert is offline
Old 08-01-2004, 8:48 PM   #2 (permalink)
overkill's Avatar
Thanks: Gave 228, Got 539
Try hearing em' all!! That way you can make your choice and not look back thinking if only.....................! I would opt for the Arcam, but thats because their sound suits me. Might not suit you though!!
The Azure has been well recieved as has the NAD so it's all up to personal taste!! Try going into a dealer which either has your amp or will allow you to test the CD player with it. Get them to hook it up to similair speakers then choose disks you know REALLY well. Enjoy!!!
Confucious say - Never buy kit without hearing it!!!
"Someone recently said to me, there's a lot of nutters out there" "Then i saw the ABD website and realised they were right!!!"
"Yes, he's back, i've no idea why, and nobody cares anyway........."
overkill is offline
Old 08-01-2004, 8:55 PM   #3 (permalink)
rupbert's Avatar
Unfortunately the Richer Sounds in Belfast has an 'all purpose' demo room; which means its the shop floor
Almost impossible to hear the difference in kit
It will probably come down to a choice of 'how it looks'.
Cheers,
rupbert is offline
Old 08-01-2004, 9:35 PM   #4 (permalink)
overkill's Avatar
Sorry Rupbert!! If you've got £400 to spend why not look elsewhere? Heres a tasty little number for a start! ebay rotel 1070
I also spied a few ARcam 8SE's whilst there.............
overkill is offline
player, weekend
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
