Originally Posted by GBDG1 I'm getting some problems with my shoulder at the moment, and i'm not sure what to do. Unsure if i've got an injury or if it's something else. I've been on holiday for a few days, so I thought the break would solve it, but doing incline bench press today it started to be sore again.
I don't get any pain except when i'm lifting and it's only really a problem when doing something that's shoulder intensive. Any ideas about what to do? |
Which shoulder is it? 1 or both? When doing incline bench press, do you use dumbells, barbell or a smith machine?
I get some intense pain in my left shoulder very often too in the frontal deltoid area and between the joint linking shoulder and chest, only under load. It seems very much like what you are experiencing. I tend to get it when doing chest exercises, even flat chest press.
I do incline and flat press with dumbells and I made a little adjustment to the way I hold the dumbells and it has made a big difference. Instead of holding the dumbells with palms facing forwards, I now twist my wrists slightly so that my palms are facing inwards at an angle slightly. I don't recall the last time I felt that pain doing the presses this way. I've never worried about this problem though, even when I was feeling pain and there is a reason for it.
Here's the thing, I got/get that really intense pain also when doing unilateral tricep exercises like downward extensions with a handle or just the ball on the cable machine and also on kickbacks. Never when doing extensions with an EZ-bar or overhead rope and always after the muscle is fatigued (not in the first couple sets) and always in the left. So putting 2+2 together, it leads me to believe that when my left tricep is fatigued, much earlier than my right (because my right is much stronger) I start to compensate with the shoulder. I've pushed my right to the limit as well to test it and found that I do get the same pain, but for me to reach that stage it takes a considerable amount of reps.
I've tried and continue to try very hard with variations in form to try and correct this, but to no avail so far. The only thing I can do is to stop, firstly because it hurts, and secondly and more importantly at that point I'm no longer working the intended muscle.
Apologies for a long'ish reply, but I guess it's all pertinent if it in some way helps you out.
