| Westone UM1 Replacement Tips Help!
I brought a set of Westone UM1's a few months ago and totally love then, so much so that i ended up getting the misses some the other day to as she started to like them too.
I'm about to go traveling so want to get some spare tips to take with me, but I'm having trouble finding them.
When I got the UM1s they came with a short and a long set of Comply tips, but when I look to buy these all I can find are Standard and Slim Comply tips. Both look like the long ones, with the slim ones just slimmer looking so not what I'm after. Westone tell me to buy them direct from them and Comply just won't reply to my emails. Anyone know which ones the shorter tips are Westone supply with the UM1s are and where I can get them?
Thx!
