| Re: Headphones for xbox360 My tv has no headphones socket
If the cable you are using from the Xbox has phono audio out (red and white RCA plugs), just to what I do and plug them into a headphone amplifier.
Even the FiiO E5 amp would be more than adequate, will allow you to use pretty much any headphones with the TV. Will cost you about £20. Only issue with an amp like the E5 is that it only has a 3.5mm input, so you'd need a phono to 3.5mm male jack adapter, you can get gold plated ones on eBay for a couple of quid including postage.
