| Shure SE110 - right ear quiet fade problem
I'm on my newly opened second pair of these 'phones after a warranty replacement, but these too exhibit the same problem.
Every so often, perhaps 5 or 10 minutes, the right ear will fade to quiet or nothing. Sometimes the left ear will follow.
It seems to be something to do with the junction of the extension cable - if I remove the headphone jack from the socket of the extension and then replace, it usually corrects itself. But then other times I need to fiddle with the solid moulded bit either side of the jack or socket - it's very annoying.
I can't see any mention of this on the tinterwebs, but seeing as I've had this twice from new I can't believe noone else is having similar problems....
Anyone? Anyone?
Ta!
Update:
I've used a different pair of headphones in the Shure extension cable - no problem.
I've used a different extension cable with the Shure 'phones - similar/same problem as with Shure extension cable.
I'm guessing the jack is the wrong dimension (but.... it's a 3.5mm jack, right?)
Reason: Additional info
