05-01-2009, 1:36 PM
#1 (permalink)
| | Member
Thanks: Gave 12, Got 8 | Budget Home Cinema Headphones
I'm looking to get some headphones for late night film watching.
I don't do it that often so I'm not looking to spend that much.
I want something that sounds half decent but doesn't break the bank so I've been looking at these two. Sennheiser HD 212 Headphones Sennheiser EH 250 Headphones
Are either of these going to be OK connected to my Denon 1906 Amp or should I be lokking for something a bit more expensive?
05-01-2009, 2:58 PM
#2 (permalink)
| | Member
Thanks: Gave 72, Got 71 | Re: Budget Home Cinema Headphones
Was alerted to a Creative set also on offer at play.com if you can stretch an extra tenner on your budget. They are essentially rebranded Denon AH-D1001s which retail at £90. Creative Aurvana Live! Headphones
Can't vouch for these specifically or the Senns you've noted but the 1001s I have found leak very little and are very comfortable.
HTH
__________________ losing my edge PSN bristolterra
05-01-2009, 7:15 PM
#3 (permalink)
| | Member
Thanks: Gave 12, Got 8 | Re: Budget Home Cinema Headphones
Cheers for the recommendation.
I didn't think of Creative for home cinema as they are more of a PC brand. A guy at work has got a set of Creative headphones for gaming and he says they are great.
I'm going to try and find some reviews but they sound like the front runner. |
08-01-2009, 2:38 PM
#4 (permalink)
| | Member
Now I've done what I always do and researched too much
I've been really impressed by the reviews of the Sennheiser HD555 and they look a different league.
Would the differences be night and day between the Creative's and these?
Anyone know where I can go to listen to a few of these headphones? I'm going to go to Richer Sounds at the weekend to take a look at their Denon ones (which seem pretty reasonable) to get a bench mark.
02-02-2009, 1:11 PM
#5 (permalink)
| | Member
A quick update just to complete the thread.
In the end the Sennheiser's went up to £95 which was a bit too rich for me.
I went to Richer Sounds to have a listen to the Denon's and was very impressed. So on the assumption the Creative’s were the same as the next Denon model up I decided to go for them.
After giving them a good test I'm pleased to say I'm very happy with them. They are exactly what I was looking for. I’m going to need to get another extension cable but that’s not the end of the world.
The only problem I’ve got now is I want to watch every film using them!
Pros
Feel well built
Very comfy
Good price (£40 now £60)
Good at reproducing home cinema sound
Cons
The extension cable could’ve been longer
Extension cable is a little ‘cheap’ feeling
Shiny ‘piano black’ finish shows finger prints
The Cons are just nit picking but I couldn’t just have all Pros. |
03-02-2009, 3:53 PM
#6 (permalink)
| | Member
Thanks: Gave 0, Got 0 | Re: Budget Home Cinema Headphones
Thanks for coming back and reviewing those Creative headphones. I'm looking for something similar, but think I might go for the Sennheiser HD 555 now that the Creative ones are up in price.
03-02-2009, 6:05 PM
#7 (permalink)
| | Member
Thanks: Gave 12, Got 8 | Re: Budget Home Cinema Headphones Quote:
Originally Posted by r0cky Thanks for coming back and reviewing those Creative headphones. I'm looking for something similar, but think I might go for the Sennheiser HD 555 now that the Creative ones are up in price. | No problem.
I think my choice would've been different if the Creative's had been £60.
All in all pretty happy, just got to find an extension cable now. |
03-02-2009, 6:40 PM
#8 (permalink)
| | Member
Thanks: Gave 43, Got 60 | Re: Budget Home Cinema Headphones Quote:
All in all pretty happy, just got to find an extension cable now.  | This cable is the nuts for extending headphones.
comes in 3m, 5m and 10m lengths.
__________________ PJ: Infocus IN80 | Screen: Optoma Panoview 92" DE9092EGA | TV: LG 42PC1D with SkyHD & Cable | Amp: Pioneer SC-LX81 | Speakers: Front MA GR60's, Centre MA GSLCR, Rear MA GSFX's | Sub: BK Monolith DF | Remote: Harmony 1100 | Gaming: PS3 & Wii | Headphones: Sennheiser 595. Showoff's Home Cinema
04-02-2009, 6:50 PM
#9 (permalink)
| | Member
Cheers for the advice but I'd already purchased a 3M Belkin one. |
08-02-2009, 11:40 PM
#10 (permalink)
| | Member
Thanks: Gave 3, Got 13 | Re: Budget Home Cinema Headphones
I am now on the hunt for a pair of headphones for late night blu ray watching and ps3 gaming. The Creative headphones at the moment come in at £60. Are these still the recommended headphones at this price or is there something else out there anyone can suggest ? Dont want to spend more than this tbh.
Headphones will be connected direct to the tv (no amp), perhaps these might be best ? http://www.play.com/Electronics/Elec...ml?source=9593
Just been trying my £15 Sony headphones through my LCD Samsung. There is a constant hiss when you mute the tv. Is this normal with headphones ?
Thanks in advance for any help
09-02-2009, 6:40 PM
#11 (permalink)
| | Member
You can get a set of Sennheiser HD555 for around the £60 mark. Might be worth a look? sennheiser hd 555 - Google Product Search
I had to buy from play as I had vouchers.
10-02-2009, 8:13 PM
#12 (permalink)
| | Member
Amazon are selling the Sennheiser HD 555 for £56.72, just ordered a pair. Amazon's price has been fluctuating, I've been watching over the last few weeks.
11-02-2009, 2:04 AM
#13 (permalink)
| | Member
Thanks: Gave 3, Got 13 | Re: Budget Home Cinema Headphones Quote:
Originally Posted by r0cky Amazon are selling the Sennheiser HD 555 for £56.72, just ordered a pair. Amazon's price has been fluctuating, I've been watching over the last few weeks. | ditto that
delighted to see them back in stock !
hope they are worth it
11-02-2009, 3:47 PM
#14 (permalink)
| | Member
Thanks: Gave 49, Got 16 | Re: Budget Home Cinema Headphones Quote:
If I purchased these would I be able to plug in to my AMP???
I need a budget set of good quality headphones for late night movie watching and PS3 gaming. They'll be plugged in mostly in to my Onkyo 506. Would these be ok for the job??
Would I still get the surround sound effect??
Panasonic Viera TH-Z50B, KEF KHT 3005SE, Harman AVR-145 AV Receiver, Jamo A102HCS5, InFocus X9 - DLP Projector, Onkyo 607, PS3, Nintendo Wii, i-Phone 8gb, PCH A-110, WD HD Media Player, PS3 40GB-Gamer I.D- rev1ll
11-02-2009, 7:50 PM
#15 (permalink)
| | Member
Thanks: Gave 0, Got 0 | Re: Budget Home Cinema Headphones Quote:
Originally Posted by PAUL7331 If I purchased these would I be able to plug in to my AMP???
I need a budget set of good quality headphones for late night movie watching and PS3 gaming. They'll be plugged in mostly in to my Onkyo 506. Would these be ok for the job?? | Yes, I believe the Onkyo TX-SR506 has a headphone socket. They should work fine, I believe the Sennheiser HD555 are reasonably easy to drive with 50 Ohm nominal impedance. My main pair of headphones are the Sennheiser HD580s. I'm hoping that the HD555s are as comfortable, looking from the photos I believe that they will be. To me, the sheer comfort of the Sennheiser outweighs any sound imperfections; but for most of my listening (TV & poor quality MP3/AC3 tracks), the limitation is the source material. Quote:
Originally Posted by PAUL7331 Would I still get the surround sound effect?? | I don't know, not something I was looking for, and its not something that the Sennheiser does per se. I'm a little sceptical about headphones that claim to reproduce a surround affect, but then I'm not a big fan of surround sound. The only aspect I like of surround sound, is the central speaker for clear, locked dialogue to screen.
