04-10-2008, 7:05 PM
#1 (permalink)
| | Member
Thanks: Gave 0, Got 8 | Need Headphones that dont mute speakers...
This is an odd one as I dont know where to post this...I don't even know if there is a solution but I heard from my mums nans brothers auntie that it was possible.
I am very partially deaf. My wife is not. Therefore the TV is up to loud all the time (for her).
I want to be able to buy headphones that dont mute the speakers for her. The added complication is that we dont use the TVs speakers. I have an Onkyo 605 surround sound amp. Obviously if I plug headphones in, the speakers mute. Also the amp is about 8 meters away so the solution also has to be wireless.
Is this possible please???
04-10-2008, 7:28 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 165, Got 109 | Re: Need Headphones that dont mute speakers...
Hi. If the onkyo amp has optical out, you could always invest in a 'beresford tc-7510 dac' and a 10m optical cable off ebay. Then plug a decent set of headphones into the dac.
There may also be a setting in the onkyo amp to allow sound through speakers with headphones connected. cheers pixel
__________________ Fluker "It aint possible to live unless you crossing somebody's line..."
04-10-2008, 11:08 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 72, Got 127 | Re: Need Headphones that dont mute speakers...
You will have to go for an external amp. Its not the headphones themselves that mute the speakers, its the electronics in the TV that detect when the headphones are plugged in which automatically mutes the speakers.
Try visiting www.headphone.com if you look in the product page, it will show you a list of wireless models, but ultimately, you are going to need some kind of amp.
One thought that comes to mind is a set of Pioneer wireless headphones I used to own, I think they were called DIR-800C or something like that. They came with a wireless base unit which was fed by a digital output. Was under £200. Sounds expensive, but something like that would, perhaps, be the optimal solution. That said, I'm sure Philips had a rival set not long after which was cheaper and better. In the end I reverted back to wired ones, but that might not be an option for you (not without a long cable, anyway).
__________________ HOME CINEMA: TV: Panasonic TH42PX70 Satellite: Thomson Sky HD Media PC / Gaming rig: HP Pavilion Elite M9361 HIFI: Source: HP Pavilion Elite M9361 into Beresford TC-7510 Mk6 Amp: Harman Kardon HK6550 Speakers: Rega Ela Headphone rig: ANT Audio Amber into Sennheiser HD600 |
05-10-2008, 9:47 AM
#4 (permalink)
| | Senior Member
Hi again. Heres a link to the Beresford amp. http://www.homehifi.co.uk/TC-7510/orderuk.html
For ease you can also choose to purchase with coaxial or optical cable if you like. Thats if you were to position the amp close to your onkyo. This would mean that you would either have to go the wireless headphone route, or accept a longer headphone cable from your sitting position to the amp.
The other option is to hide a long (10m+) optical cable under the carpet from the onkyo amp to the beresford (your sitting position) and the just plug in sitable headphones.
Regarding wireless headphones here are a few options http://www.audiocubes.com/category/H...cy=GBP&sort=5a
or sennheiser SR 130' http://www.play.com/Electronics/Elec...s/Product.html
sr 140's http://www.amazon.co.uk/Sennheiser-1.../dp/B0007WGSMU
bear in mind that the sound quality will be better from a similarly priced quality wired headphone.
fyi i have the beresford and am very please with the sound quality both from the headphone out to external amp and speakers.
the other option is to replace your onkyo amp with an amp that doesnt shut off sound to the speakers when headphones are used. but i dont know of an amp that does this. im sure someone else on these forums might though. cheers pixel
06-10-2008, 11:31 AM
#5 (permalink)
| | Senior Member
Thanks: Gave 142, Got 268 | Re: Need Headphones that dont mute speakers...
I'd recommend the Sennheiser wireless solutions, they are cheaper and will get the job done, too (no surround sound, though).
The "mute" problem is not in the headphones, though. You will need to use a "tape out" in your receiver, or similar (instead of the digital out mentioned above) so that you can hear the same that the speakers are playing.
__________________ Wish list: Harmony 1, WooAudio6, a detached house |
06-10-2008, 12:28 PM
#6 (permalink)
| | Senior Member
why wont the digital out give the same signal as tape out. I was thinking along the lines that digital out would send whatever signal the amp was currently sending to the speakers? cheers
__________________ Fluker "It aint possible to live unless you crossing somebody's line..." |
06-10-2008, 1:12 PM
#7 (permalink)
| | Senior Member
Thanks: Gave 142, Got 268 | Re: Need Headphones that dont mute speakers... Quote:
Originally Posted by pixelpidgeon why wont the digital out give the same signal as tape out. I was thinking along the lines that digital out would send whatever signal the amp was currently sending to the speakers? cheers | That's a good question.
I do not know if the AVR digitizes the analog signals and outputs them over the digital out.
I do not know either if the digital inputs are output over the tape out.
Thus, maybe both are needed. Check the manual.
But my suggestion was rather to introduce a cheaper solution, I have nothing against the digital out
07-10-2008, 4:48 PM
#8 (permalink)
| | Senior Member
glad to hear it!  no seriously, i was interested, as it got me thinking about maybe only a certain digital signal was passed through and not whatever the amp is currently 'playing'. In fact, you have pointed this out. cheers Quote:
But my suggestion was rather to introduce a cheaper solution, I have nothing against the digital out  |
08-10-2008, 10:02 AM
#9 (permalink)
| | Veteran Member
Thanks: Gave 76, Got 211 | Re: Need Headphones that dont mute speakers...
I'd be wary of using the digital output - you wouldn't be wanting DD or DTS signals being sent to a DAC that won't decode them.
Coming out of the tape output and straight into a wireless headphone base station would seem like the easist option to me. |
08-10-2008, 10:34 AM
#10 (permalink)
| | Senior Member
Originally Posted by eviljohn2 I'd be wary of using the digital output - you wouldn't be wanting DD or DTS signals being sent to a DAC that won't decode them.
Coming out of the tape output and straight into a wireless headphone base station would seem like the easist option to me.  | But what happens if a digital signal is fed into the receiver? Do you get plain stereo out of the tape out for those too? I don't think so  And thus, it wouldn't be a complete solution.
08-10-2008, 11:37 AM
#11 (permalink)
| | Senior Member
see what you mean. apparently there is a way to se the digital out of a sky box to stereo. But this would only affect sky viewing and not dvd player etc.... and also would reduce the when watching something that includes surround sound and listening through a surround system and amps.
i agree then that tape out to wireless headphones seems a good way to go.. Quote:
08-10-2008, 11:41 AM
#12 (permalink)
| | Senior Member
Thanks: Gave 165, Got 109 | Re: Need Headphones that dont mute speakers...  the more we delve the bigger the can of worms hehe
wheres the op gone... on holiday Quote:
Originally Posted by cribeiro But what happens if a digital signal is fed into the receiver? Do you get plain stereo out of the tape out for those too? I don't think so  And thus, it wouldn't be a complete solution. |
11-10-2008, 3:38 PM
#13 (permalink)
| | Member
Thanks: Gave 17, Got 16 | Re: Need Headphones that dont mute speakers...
Maybe I'm reading the OP wrong but.....the answer here is simple with no need for optical, DACs, line level, etc.
Wife listens through Onkyo amp and speakers at a volume comfortable for her.
Hubby listens through headphones connected to TV, headphones mute the telly speakers and voila!
Headphones connected to the telly can be wired or wireless if preferred.
This assumes the telly has a headphone socket. I'm guessing it has if it has a line level out to the Onkyo amp.
Hope this helps
Pablo
__________________ AV- TV: Panny TH42-PZ80, Blu-ray DVD: PS3, SKY: Pace Sky+ Box, AUDIO- CD: Cyrus CD7Q, AAC: 32GB iPod Touch, PRE-AMP: Cyrus Aca7.5, POWER-AMP: Cyrus Mono X x 2, SPKS: Dynaudio Contour 1.1, GAMING- PC: Hand Built Core2Duo E8400 OC 3.6Ghz, ATI HD3870, Sony 19" SDM-E96D, XBOX360, Wii, PS3 |
14-10-2008, 12:30 PM
#14 (permalink)
| | Member
Thanks: Gave 0, Got 8 | Re: Need Headphones that dont mute speakers...
Hi!
For some reason AV Forums didnt notify me of the responses so I assumed no-one cared
I want a simple no frills solution is possible, I just dont want to alter the sound config of the external speaker. Perhaps a little connection info will help.
Firstly, TV has NO speakers but does have a headphone socket.
TV is connected to Onkyo Amp via HDMI. The HDMi is obviously carrying picture only to the amp as the TV has no speakers.
Can I just plug headphones in to the TV then as Pablo suggested!!!?
Why do I think it wont be that simple |
15-10-2008, 7:45 AM
#15 (permalink)
| | Prominent Member
Join Date: Apr 2006 Location: You'd get your feet wet getting here
Thanks: Gave 198, Got 456 | Re: Need Headphones that dont mute speakers... Quote:
Why do I think it wont be that simple  | why don't you try it and see? surely you have a pair of headphones lying around, it won't do any damage.
__________________ My Home Cinema Room My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, 7.1 B&W 6 Series speakers, Panny BD35(now Region free for Blu-ray!!), HTPC, XBOX 360, WII
