Originally Posted by jl151080 Thanks for your reply.
I'm not happy with the sound I am getting through the socket on my Cambridge Audio amp. Strangely, I get a much better/clearer sound when I use the HD590's with my Ipod!
I assumed, therefore, that the sound quality would be vastly improved by adding a separate headphone amp to my system?
I'm surprised that you don't think much of the HD590's - they seem to be fairly highly regarded by a lot of people. |
Well from what you describe (i.e. its better from your ipod) I would suggest it seems like the Cambridge amp has a high output impedance at the socket. This is normally caused because it uses a simple resistor from the output stage (basically just to limit the power going to the phones or it would blow the headphones). With the 590 being a low impedance phone, it will be quite badly affected by this.
Basically when an output has a high impedance, it adds to the impedance of the headphones themselves and drastically changes the frequency response. The effect it has is usually that it makes it sound a lot warmer, and thus might come across as muddy and slow.
On the other hand your ipod will have a very low output impedance (which is optimal).
In your case, an amp would definitely clean the sound up. However, I still dont recommend you spend a lot, because even relatively cheap amps will do the job perfectly well. I would avoid the Creek stuff though as those amps still have a relatively high output impedance for some reason.
Also its not that the 590s are bad, but they arent good enough to justify £300+ on an amp IMHO.
