Originally Posted by Hawkins85 Cheers. I could get the Creek-OBH-11 (with OBH-UNI power supply) for £95, if I can ascertain this would at least equal the quality & high volume of my existing amplifier but without the clipping on those extremities, the problem I am concerned with would be solved.
Alternatively, I know closed headphones have limited acoustic capabilities compared to open designs but within the limitations of my existing setup, I'm convinced I'm having to overcompensate the volume because the bass I need is being diffused outward through those grilles and that the problem would at least also be able to solved by using a closed design with the existing amp at lower volume, but of course this would be less preferable than if a dedicated headphone amp could solve it on open design reference class headphones. There are some really old closed headphones I have around here somewhere, they're pretty dull sonically but at least there's little trouble feeling the bass on them. I'll have to try them again and listen to how well they handle "The Matrix".
Sources include CD>Dolby True HD/DTS Master Audio/SACD/DVD-Audio. Though sadly I don't exactly have a lot of SACD/DVD-Audio titles due to lack of popularity with both formats. |
Think about a loudspeaker. They have a cabinet, which is braced and damped to avoid vibrations, so that all the sound you hear comes from the driver (and reflex port, if present) in a clean and undistorted way.
If you plug a poor amplifier, it will sound terrible, right? In principle, you could remove the damping materials and internal bracing, but nobody does... If you did that, the loudspeaker would vibrate and add up to the sound. Maybe resulting in a louder bass. The problem is that, even although louder, the sound will be poorer, because those vibrations are distortions of the original sound, that is why they have to be damped.
The same happens with your headphones. "Closing" them adds bass to the sound, but not sound quality. It is like breaking a leg and taking loads of pain killers so that you can keep walking.
A good closed headphone will work like the loudspeaker: the sound that in an open design leaks out needs to be damped. It is not used (
AFAIK) to add to the sound, because it would distort it. Thus, if you still use poor or underdimensioned amplification, you will not get rid of the problem. If the closed headphones you have sound fuller in the bass, is only because they demand less from the amplification, not because they are closed.
So don't think that the bass you need is been leaked out, that is a misconception: the bass you need is being distorted by the amp, which cannot cope with it.
Regarding amplifiers for your HD650, I cannot tell you much first-hand information. I have used the headphone out of my Azur 640A, a Corda Aria, a Corda Porta II and a Woo Audio WA2. All of them drove them well, with the Azur having enough power but little bass control, the Aria having control, but lacking "emotion" (
), the Porta having control and enough power, but not "finesse" (
) and the Woo having everything you could ask for. I guess the Creek will have enough power to drive them to high levels without distortion (like the Porta did), but I cannot say much about its sound quality. It should be better than your present solution, though.
If you want to get more from your money, maybe you should look into the second hand market, so that you can afford a 500 euro amp for 250 euro.
And if you want to get a taste of what good amplification can do, ask your local dealer if you can test your headphones with a decent amp (good stereo amps have also a decent headphone out, my Azur 640A for example, had loads of bass, maybe not fully controlled, but never clipping).
