| Re: Noise Cancelling of Neighbours Bass
ear plugs are the best (and cheapest) way to eliminate unwanted sound. not the most comfortable though.
NC headphones are best at reducing constant drones, like planes, fans etc. changing sound is harder to cancel. i'm not sure a set of headphones will really make that much difference.
the PXC450s can be used with or without noise cancelling. You can also use them without a cable if you wish. They are not great for sleeping with - they're too big for that. I don't think any over the ear phones will work for sleep. Again, ear plugs are probably the way forward.
really good headphones btw
