| Re: DAC/Headphone amp recommendations
This thread would probably do much better in the headphones section.
I will move it there and leave a re-direct here to it.
On the original topic.....a headphone amp can make it possible to extract the best from a decent set of headphones,but not all headphone amps are equal (to paraphrase Orwell).
There are a vast number available currently,from very cheap amps at £50 or less,right up to some costing well over £1k.
The amp suggested above is fine and would do a very good job,but you should also consider the MF X-Cans,and several others.
There are a few quite reasonably priced DACs around as listed above,and the US based Headroom range also includes a few DAC/amp combos.
