27-05-2008, 12:34 AM
#1 (permalink)
Thanks: Gave 3, Got 4
Decent closed headphones?
As the title says, because at the moment I have Sennheiser HD600's, but my family are not happy because as they are open, whenever I listen to my music in the living room (as I use my laptop) they can all hear it above the tv, even when I have it as quiet as I can get it.
That forces me to buy another pair, so rather than rush to Argos and buy the best pair they have available, I want to have closed headphones for my money, and thought I would ask you good people here what you would recommend?
I dont mind if they are wired (as they are the better quality) but the only limiting factor is the price I can afford, hopefully I wouldnt have to pay more than around £50 for them, but I need decent quality sound, especially the bass noise with the kind of songs I have.
27-05-2008, 5:57 AM
#2 (permalink)
Thanks: Gave 28, Got 21
Re: Decent closed headphones?
I'm glad I stuck with Shure. They cost £60 for the budget ones and block out sound very well. If you want to listen to anything on the train or at home without disturbing the person next to you get those.
SONY BRAVIA 26"-PS3 60GIG-ONKYO 705-SILVER QED ANNIV EDITION-MONITOR AUDIO RADIUS 180-225-MONITOR AUDIO GLSR10-SONY VINYL PLAYER-CANON A620
PS3 HANDLE - tdtm82
27-05-2008, 7:36 AM
#3 (permalink)
Could you tell me what model Shure that you recommend? And also a link to where you can buy them now for £60 (or less if possible)
27-05-2008, 7:52 AM
#4 (permalink)
Thanks: Gave 198, Got 454
can well recommend shures if you're okay with in ears. i have the e3c's and love them. if you want proper cans the senn hd280s are pretty good. a bit analytical, but i still like them
My Home Cinema Room
My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, 7.1 B&W 6 Series speakers, Panny BD35(now Region free for Blu-ray!!), HTPC, XBOX 360, WII
28-05-2008, 11:11 AM
#5 (permalink)
I already have some Westone UM2's, with custom made ear moulds, but I only use them for outdoors, as I would prefer proper cans for listening to music indoors.
Any links to these decent headphones?
29-05-2008, 10:10 AM
#6 (permalink)
Assured Advertiser
Thanks: Gave 2, Got 30
Have you considered the Audio-Technica ATH-AXXX range? Maybe the Audio-Technica TH-A500 closed back or Audio-Technica ATH-A700 closed back?
I've got a bit of a soft spot for Audio-Technica headphones. Their sound is somewhere between the smoothness of Sennheiser's and the up-front sound of Grado headphones. In other words nicely balanced.
Shaun
30-05-2008, 11:36 AM
#7 (permalink)
Thanks: Gave 4, Got 19
I bought some Sennheiser HD280s recently, because they were said to be excellent at keeping out ambient sound (I have noisy neighbours). Unfortunately I found them too tight for comfort (maybe I have a big head). So I have a pair available for sale, hardly used (PM me if interested). Would also be interested in suggestions for a pair that are good at keeping out noise AND comfortable AND cheaper (as I don't want to risk paying that much again in case they don't suit me either).
30-05-2008, 12:53 PM
#8 (permalink)
the hd280s are tight to start, but they do loosen up a lot..try stretching them over something
My Home Cinema Room
30-05-2008, 1:39 PM
#9 (permalink)
Thanks for the suggestion. I left them stretched over some books for a couple of days. Didn't help. Perhaps I need to leave them like that for longer. I was afraid of breaking them if I overdid it.
30-05-2008, 1:56 PM
#10 (permalink)
i have a pair about 3 years old. work bought me a new pair last year, putting on the new ones is unbelievably tight compared to the older ones
My Home Cinema Room
31-05-2008, 9:26 AM
#11 (permalink)
OK. I'll give them another try.
08-06-2008, 10:43 AM
#12 (permalink)
Try leaving them on a size 5 football for a few days - worked for me.
09-06-2008, 4:22 PM
#13 (permalink)
Any other closed headphones that will work and be really comfortable from the get-go? I just want a pair that can reproduce the sound almost as well as my HD 600's, but without the ludicrous price tag that I paid for these at the time.
09-06-2008, 7:20 PM
#14 (permalink)
Thanks: Gave 72, Got 127
You're asking an awful lot to get something that gets anywhere near the HD600 and closed for £50 or under. The best suggestion I can come up with is the Beyerdynamic DT250 as they sound quite similar but are at least £75...
HOME CINEMA: TV: Panasonic TH42PX70 Satellite: Thomson Sky HD Media PC / Gaming rig: HP Pavilion Elite M9361
HIFI: Source: HP Pavilion Elite M9361 into Beresford TC-7510 Mk6 Amp: Harman Kardon HK6550 Speakers: Rega Ela Headphone rig: ANT Audio Amber into Sennheiser HD600
10-06-2008, 12:35 PM
#15 (permalink)
Thanks: Gave 134, Got 26
If you want some really good closed headphones my advice is save up a bit more and buy some Sennhesier HD250 Linear II's, - I swear by them, - I have had HD600s and the HD250 II sound a lot better IMO. It is not just me who thinks so, - Graham Slee (maker of the Solo headphone amp) thinks they are better sounding than the HD600/HD650 as well. They have increcbile bass yet are very transparent, musical and higly detailed as well. The HD600/HD650s sound darker to me and not as clear.
They would cost around £120 but would last you for years, - my first pair lasted me for ten years before a driver capsule blew, - I immeditely bought another pair and have no doubt they will last as long.
I would not spend any less, - you will not be happy with the sound. The HD250IIs are 300ohms and not very sensitive, - they will not work well with an Ipod, - you won't get enough volume. If you want a heapdhone that is more compatibile and portable look at the hugely popular Sennshier HD25-I, - not bad at all are very sensitive and easier to drive. They are not in HD250/HD600 league but acceptable. However though they will cost £110+ as well. However they are supraaural and not as comfortable as the other bigger models.
Also note the HD250II (like the HD600) are circumaural and are extremely comfortable.
When my first pair of HD250 II broke I replace them with some new HD600s thinking they would be better, - they were not! I quickly sold the HD600's and got another pair of HD250IIs (which are just as brilliant as my first pair). If you don't want to spend too much on a new pair sell your HD600 and put the money towards some HD250II, - if you had some HD250II you would never use the HD600s, - they simply do not sound as good!
if you are near near London you are very welcome to have a listen to my HD250IIs and compare them to your HD600s.
Cheers,
Colin
