Go Back   AVForums.com > Audio Electronics > Headphones and Headphone Amps
Today's price checkPowered by
Bose On-Ear Headphones
Bose In-Ear Headphones
Bose Around-Ear Headphones
Sennheiser CX 300-II
Sennheiser RS 130
Sennheiser CX 400-II
Sennheiser PX 100
Sennheiser CX 300
MonsterCable Beats by Dr. Dre
Sennheiser PXC 250
 More...Prices updated November 23rd at 4:30am and include delivery.
Shure E500 In Ear Monitors - Early impressions doctorjuggles Headphones and Headphone Amps 29 20-03-2007 2:36 PM
Shure E500 - awesome eugdog2 Headphones and Headphone Amps 19 16-02-2007 5:29 PM
Shure E500 What Hifi review... anyone know a link? SAP7 Headphones and Headphone Amps 3 30-10-2006 10:36 AM
Old 14-05-2008, 2:28 PM   #1 (permalink)
Thanks: Gave 29, Got 1
Shure E500 vs E530 vs E5
I've currently got the E5's. Love the sound (even with my iPod Classic) but find them very uncomfortable so cannot use them for long periods (I fly long haul a lot so this discomfort issue is a big problem to me). So I'm looking to replace them with the E500 or the E530 (both look a lot more comfortable)
But does anyone know the difference between the two? I read on another thread that they were the same - but on Amazon the E500's are over £100 more expensive so I'm guessing there is a difference.
Also, anyone out there gone from the E5's to the E500 or the E530? Was there a difference?
keithlewin is offline   Reply With Quote
Old 14-05-2008, 4:56 PM   #2 (permalink)
xPositor's Avatar
Thanks: Gave 12, Got 28
Re: Shure E500 vs E530 vs E5
Don't get completely new headphones - get yourself a pair of custom-moulded earpieces to fit on them. A colleague at work has just had this done and is very impressed. Not as expensive as you might think (or so I thought, anyway). Take a look at http://www.enhancedlistening.co.uk/p...D=270&P_ID=972
xPositor is offline   Reply With Quote
keithlewin (14-05-2008)
Old 14-05-2008, 7:19 PM   #3 (permalink)
Thanks: Gave 47, Got 207
The E500s are identical to the SE530s - the only difference is that they are a different colour! When they launched the SE series to replace the E series, Shure decided there wasn't much they could do to improve the E500s, so they just changed the model number and the packaging. It's safe to buy whichever is the cheapest - although check that you are getting the PTH (Push-to hear) accessory with both when comparing prices.
Oh, the only other difference is that the SE530 comes with Shure's new design of black foam earplug, as opposed to the old yellow design, in the "Fit Kit".
As to sound quality, I've never listened to the E5, but I own a set of E500s, and they are easily the best headphone I've heard. I did have a set of E3s, but the E500s blow them out of the water - they give a much fuller sound. Bear in mind, though, that if comfort is the problem with your E5s, the E500 uses exactly the same earplugs, so is unlikely to feel much better in the ear.
spl23 is offline   Reply With Quote
Old 14-05-2008, 9:23 PM   #4 (permalink)
The "in ear" bit is okay, it's the rest of the fitment that you seem to have to lock into the rest of your ear (on the E5 it's a squarish thingy - something they appear to have rounded off with the look of the E500/530). The sound is great though - i bought a pair of Bose Q3's to help with the long haul listening - but they don't even come close.
Old 14-05-2008, 9:29 PM   #5 (permalink)
Wow, great advice - thanks. Will get onto them tomorrow. I've done a bit more research too and it appears the 500/530 is actually a step up from the E5's. So being a compulsive obsessive I may even go for the 530's (with PTH) AND get the custom-moulded earpieces. Hey, long time dead eh?
Old 15-05-2008, 6:23 PM   #6 (permalink)
xPositor's Avatar
If you do go the moulded earpiece route, can you post back how you get on with the whole experience?
Old 15-05-2008, 10:43 PM   #7 (permalink)
Thanks: Gave 89, Got 112
I would also be interested to find out how you get on. I have has the SE530s for a few months now, and it took me a while to get used to any of the standard fittings. I am getting on fine with them now, and they are excellent, but would be interested to hear if £85 takes them to yet another level.
daveb975 is offline   Reply With Quote
Old 16-05-2008, 8:43 AM   #8 (permalink)
Thanks: Gave 35, Got 21
Interesting to read about the custom impressions.
I have the 500s and so far I'm perfectly happy with the new black foamies. They are extremely comfortable and secure. At first, I was wearing them with the wires looped over my ears, but the wires are so stiff and heavy I was always aware that it was rubbing against me. Now, I just wear them like regular ear buds, and the foamies hold them very securely in my ear, and I don't have that irritating cable running all round my face. (Pus, it doesn't take 10 minutes to get them on any more!). I might just be lucky though.
If you find them comfortable with the stock tips, I'm not really sure what advantage the custom earpieces offer? Even the blurb on the website doesn't say.
Keiron is offline   Reply With Quote
Old 16-05-2008, 8:47 AM   #9 (permalink)
Thanks: Gave 0, Got 7
Customs are a nice idea i think, but not on a universal IEM. Id only go that route if i could not get a proper seal otherwise id go all out and just get full customs.
Don't mean to Hijack the thread but has any E500/E530 users had any problems with their cables fraying?Its well documented over on headfi and it put me off going for E530's after my E4g died.I went for Westone UM2's ,its a different sound signature so its taking a bit of getting used to.
padi89 is offline   Reply With Quote
Old 16-05-2008, 9:21 AM   #10 (permalink)
I've only had mine a few weeks, but just looking at and feeling the cable leads me to expect there will be problems. Why couldn't they use something more flexible?
The only other negative also relates to the cable. As supplied, the cord is extremely short. When I wear them in regular fashion (ie not over the ear) and listen to my portable in my shirt pocket, it just about reaches (but the plug is stupidly big). I think the idea is that you use one of the 2 extensions supplied: one about 9 inches, the other about 9 miles. You end up with a great heavy, clumsy, ugly mess of black plastic jacks and sockets.
It just makes no sense to me. Why didn't they just make the cable nine inches longer in the first place?
Old 16-05-2008, 11:28 AM   #11 (permalink)
I've been using my E500s on a pretty much daily basis for about a year now, and there is absolutely no sign of damage to the cables. I do look after them - they live in the storage case when not in use, and I am always careful about coiling the cable, but there doesn't seem to be a problem with wear in normal usage. The lack of flexibilty of the cable is actually an advantage - after a while, the loops of cable that go behind your ears cause the cable to settle in that shape, so there is no constant bending and unbending in that area.
Old 16-05-2008, 4:12 PM   #12 (permalink)
I've made the appointment for the ear impressions next Thursday (earliest I could get).
The price for the impression is £25 PER EAR plus VAT
Then it's £60 for the mould/earpiece itself (+VAT) so it's going to cost around £130 all up, so I hope it makes a big difference!
I ordered the SE530PTH's yesterday for £240 through Amazon (good price I thought).
I'll keep the thread updated with how I get on.
Haven't had any cable issues with the E5's by the way. But I find them a tangled pain to put on!
Old 17-05-2008, 9:41 AM   #13 (permalink)
£370 for a pair of IEMs, when some owners prefer the E5 anyway. Yikes!
Why didn't you wait and see how comfortable you find the stock SE530s before getting the custom fits? I find they are extremely comfortable and secure, either over the ear or conventionally, not least due to the new, shaped black foamies. In fact, couldn't you just have tried a pair of them on the E5s for the sake of a tenner?
Old 17-05-2008, 11:23 AM   #14 (permalink)
StevieDvd's Avatar
Thanks: Gave 36, Got 87
ACS do custom sleeves for £88 which I believe includes the cost of the impressions.
Wherever you get them done though make sure they provide a good seal, if not good it ruins any semblance of bass.
You can download a couple of test mp3 tracks to test this, which I found really helpful when I had my customs made up. If you do pay £130 for the sleeves don't accept a bad fit, the difference between a good seal and a bad one makes a noticeable change in the sound quality.
As for the process here's a post I made about this earlier.
PS I don't work for ACS and am not on commission
Steve
StevieDvd is offline   Reply With Quote
keithlewin (17-05-2008)
Old 17-05-2008, 11:51 AM   #15 (permalink)
All good advice, thanks. I'll try the 530's before I go for the impressions and make a decision.
Anyone got any ideas on how much I should sell the E5's for? I've looked in the classifieds and can't see any to get a fix?
e500, e530, shure
