Originally Posted by Keiron I have been toying with the idea of getting them from Play (about £199 with discount codes etc) and seeing if I like them, but Play won't take things back if they have been opened. Can you recall whether the SE530s come in a sealed pack? |
Unfortunately, they were E500s when I bought them, so things may have changed. From memory, mine came in a very nice metal box with various "layers" of stuff inside (headphones, cables, earpads etc). This came in an outer cardboard box, and that was sealed in shrink-wrap. So if they package them the same, the shrink-wrap is your only problem. All the SE series headphones I have seen, though, have been in sealed blister packs - the ones you have to destroy to get into. I've not seen the SE530 packaging though - it may be nicer / more amenable to resealing.
The SE530s are available from Amazon.co.uk for £209, with no discount codes required, and Amazon are pretty good about taking stuff back - much more helpful than Play, in my experience. You're presumably covered by the Distance Selling Regs anyway?
