Upgrade from HD465 TO HD555/595?
Old 12-02-2008, 1:13 AM   #1
5,172, Level: 17
Points: 5,172, Level: 17 Points: 5,172, Level: 17 Points: 5,172, Level: 17
Will I hear much of a difference if I Upgrade from Senn HD465 TO HD555/595?
or even Grado 60/80's?
I'm a bit of a tart taste wise when I listen to music (i.e. ill go with anything).
My cd is a NAD C 521BEE and the amp is a NAD C 320BEE
So should I spend some money in the persuit of sound quality? or keep the HD465's
thanks,
Dizz.
Old 12-02-2008, 11:26 AM   #2
c64 c64 is offline
1,436, Level: 8
Points: 1,436, Level: 8 Points: 1,436, Level: 8 Points: 1,436, Level: 8
Thanks: Gave 0, Got 8
Re: Upgrade from HD465 TO HD555/595?
I went for goldring dr150 they look like giant killers
Old 12-02-2008, 1:02 PM   #3
4,500, Level: 15
Points: 4,500, Level: 15 Points: 4,500, Level: 15 Points: 4,500, Level: 15
Thanks: Gave 0, Got 28
thanks,
Dizz.
the answer is yes and no. some may say that things like 'the bass will be tigghter' 'more definition on the top end' 'better soundstaging' etc, but to jump from the HD595's won't be the same as jumping to the Grado's.
personally, i always found the Nad leaning to the slighly warmer side of neutral, so to balance that out, i wouldn't necessarliy go for the Sennheisers, unless it's the HD25-1 which are abnormally forward for a pair of Sennheisers.
Grado would be an obvious choice, but some complain about the lack of sound staging (not me). if you don't want a lot of bass in your sound, then i'd go for a pair of Denon AH-D1000 or a pair of Audio Technica's.
http://www.audiocubes.com/advanced_s...audio+technica (take your pick)
Old 14-02-2008, 6:03 PM   #4
5,172, Level: 17
Thanks for the reply, do you think the Goldring DR150's are an alternitive to the Grado's?
Old 14-02-2008, 10:35 PM   #5
c64 c64 is offline
1,436, Level: 8
well I sold my grado sr60 and find these better superb phones for £60 delivered.
got mine from here http://www.hifi4less.com/ they dont get much press because they are uk made and sold and people are snobbish and think expensive>cheap but take it from me these cans blow away my grado's.
Old 15-02-2008, 12:29 AM   #6
4,500, Level: 15
well my friend sold his SR225's and got a pair of DR150's and he says he doesn't regret it. he loves the Goldrings. i've just got my hands on the (pink, and no sniggering please) goldring GX200's.
i've always wanted a pair of Goldring DR's but i've never got around to buying a pair.
Old 17-02-2008, 1:51 AM   #7
5,172, Level: 17
So to recap
Senns 555/595 = good, but not so good with my NAD cd player
Grado Sr 60/80 = great but uncomfortable/fragile, no sound staging(ish)
Goldring Dr150 = great all rounder, cheaper option and gaining a fan base?
I was leaning to the Grado sr80's but have read about poor/cheap build quality and bits breaking off, also poor bass and sound staging, and low comfort levels. (Strange as they got top marks from What HiFi)
So now top of my list is the Goldring dr150's which are cheaper, more comfortable to ware, have good all round quality in both sound and the way they are made, but they just seem to be the underdogs in this battle.
Does anyone have a link to a review of the Goldring 150's? I know What hifi did one but cant find it on the net.
£60 inc p+p for the goldrings is soooo tempting I just need a little more convincing.
thanks.
Old 17-02-2008, 9:40 AM   #8
4,500, Level: 15
and it's strange how many magazines still think the ipod is the best sounding MP3 player. yet after trying the iaudio F2, i know that wasn't the case.
Grado's aren't bad at all, and i don't quite buy into the "lack of or no sound staging" argument, but it has been a while since i last heard my SR125's which i gave away. in fact i still stand by the iGrado's being THE best portable headphones under the £35.
you should look at the Alessandro MS-1 which are modded pair of SR80's for not much money. But i have to say as a bass head, the grado SR range don't really cut the mustard for me. i'd rather have a pair of Denon AH-D1000's.
this is the only review i got.
Chad wrote the following;
I would suggest the Goldring DR100 at the $100 price point. I love my DR150's (sold my grado SR225's with no regrets) and I want to buy the DR100's for portable use.
I loved the firm endorsement of the Goldrings. The particular comment that won me over is the part where Chad says in brackets,
That's a powerful endorsement if ever there was one. I do have the Goldrings in my sight, and they seem to have nothing but positive comments.
the only other option is (dare i say it) headfi.org
Old 19-02-2008, 12:38 PM   #9
5,172, Level: 17
It came down to the senn 595's and the Goldring DR150's and after reading lots of posts both here and on another forum I went with the Goldring DR150's, I have orderd them today for £60 with free P+P from
http://www.hifi4less.com/product.php/1047/0/
Ill let you know how I get on when they arrive
thanks,
Dizz.
Old 02-03-2008, 1:05 AM   #10
2,573, Level: 11
Points: 2,573, Level: 11 Points: 2,573, Level: 11 Points: 2,573, Level: 11
HI, How did you get on with the DR150's? I'm thinking of thinking of upgrading from my SR HD485s.
Thx...
Old 06-03-2008, 11:16 PM   #11
Johnmcl7's Avatar
6,737, Level: 19
Points: 6,737, Level: 19 Points: 6,737, Level: 19 Points: 6,737, Level: 19
Activity: 22.6%
Activity: 22.6% Activity: 22.6% Activity: 22.6%
Thanks: Gave 48, Got 329
I would be interested as well, I currently have a cheap pair of Panasonics which I've always like but would like something better for around 50-60 pounds. I like the sound of the Goldringer headphones and would appreciate any thoughts.
John
Old 07-03-2008, 9:07 AM   #12
3,632, Level: 14
Points: 3,632, Level: 14 Points: 3,632, Level: 14 Points: 3,632, Level: 14
Thanks: Gave 2, Got 13
Just adding my encouragement for an update.
The Goldrings are very tempting, but I think many of us would like a few more user recommendations, before buying.
Thanks.
Old 09-03-2008, 11:31 PM   #13
willharris10's Avatar
4,764, Level: 16
Points: 4,764, Level: 16 Points: 4,764, Level: 16 Points: 4,764, Level: 16
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 118, Got 147
I'd get the 595s. Definitely. They're £87 on amazon. Take a look.
I have the Ultrasone HFI-780. They're £125 from the distributor in the UK. The grados didn't do it for me. You need to take a listen. The 595s will be a big step up on your current Senns. A really good big step up. Enjoy.
Old 10-03-2008, 8:42 PM   #14
3,410, Level: 13
Points: 3,410, Level: 13 Points: 3,410, Level: 13 Points: 3,410, Level: 13
I bought the Senny 595's the other day. Lovely sound and very comfy. I asked my local Richer Sounds to price match amazon (£85) and they said we can beat them by £5, so I had them for £80.
Old 11-03-2008, 9:52 PM   #15
dazzler9000's Avatar
4,537, Level: 15
Points: 4,537, Level: 15 Points: 4,537, Level: 15 Points: 4,537, Level: 15
Thanks: Gave 57, Got 31
Bit late now, but here's a review.
http://www.stereomojo.com/GoldringDr...onesreview.htm
coliam (11-03-2008)
Old 11-03-2008, 10:33 PM   #16
3,632, Level: 14
Thanks, Dazzler9000, that's very useful.
Old 27-02-2009, 9:45 PM   #17
5,172, Level: 17
OOOPs i forgot to come back with my opinion of the Goldring 150's, sorry.
well I still have them and i do like them they sound best with acoustic music and vocals but a bit messy when listening to rock music.
They started off with lots of sibilance that made it annoying to listen to any vocalists but that has all but disappeared with extended use.
They are comfortable to wear but i find my ears getting a bit hot after an hour or so use.
Bass is good but not fantastic and the midrange is great.
So all in all would i buy them again? yes i would and im just about to buy some for my father who likes modern jazz and liked the way they separated the instruments when he listened (jazz sounds like a mess to me though)
good luck and happy listening.
Old 28-02-2009, 11:40 AM   #18
1,630, Level: 9
Points: 1,630, Level: 9 Points: 1,630, Level: 9 Points: 1,630, Level: 9
Activity: 22.0%
Activity: 22.0% Activity: 22.0% Activity: 22.0%
Thanks: Gave 26, Got 215
The thing with Senns is that they are massively comfortable. I can't understand how people can buy Grados (nothing to do with the sound quality! Before I get flamed) purely from a comfort point of view for extended listening. The ear pads don't do it for me, the circumference on the cans is a bit lacking and don't get me started on the way they are attached to the head band.
I can fall asleep in both my Senns and its not a problem and they still sound decent.
Old 08-03-2009, 1:53 PM   #19
Thanks: Gave 0, Got 16
bear in mind dizz that good cans need time to settle down(maybe 200 hours)....they may sound bright and agressive to begin with, but will mellow after this time.
Generally speaking my experience of the dr150's are that they are awsome.....
Unamped they blow any series 5 senn out of the water imo(and amped actually).....i strongly recommend the asus xonar d2 soundcard to pair with these cans.
Online most threads you come across compare them to the hd600 rather than the hd595......which is strong reccomendation in itself.
I have seen review roundups including the dr150's where the goldrings are the cheapest cans in the group by over £50 and still outperform certain other brands over £100.
They ship with a lovely silver plated qed custom detacheable lead....and are only cheaper as they are a native UK company.
Grado in the states are dirt cheap as they are made in brooklyn(from what memory serves).........same thing with goldring in the UK.
Powered by
 Latest popular product prices
Sony MDR-NC7
6 prices from
 £14.97 Click to show/hide the offers
Sony MDR-ZX300
6 prices from
 £17.63 Click to show/hide the offers
Sennheiser CX 300-II
8 prices from
 £32.99 Click to show/hide the offers
Panasonic RP-HTX7
3 prices from
 £28.89 Click to show/hide the offers
SoundMAGIC E10
2 prices from
 £34.99 Click to show/hide the offers
Sony MDR-XB500
2 prices from
 £39.99 Click to show/hide the offers
Beyerdynamic DTX 101 iE
1 price
 £52.24 Click to show/hide the offers
Klipsch Image S4i
6 prices from
 £59.94 Click to show/hide the offers
 Updated February 13th at 4:30pm. Prices include delivery.
