Go Back   AVForums.com > Audio Electronics > Headphones and Headphone Amps
Today's price checkPowered by
Bose On-Ear Headphones
Bose In-Ear Headphones
Sennheiser RS 130
Sennheiser CX 300-II
Sennheiser RS 130
Bose Around-Ear Headphones
Sennheiser CX 400-II
Sennheiser PX 100
Sennheiser CX 300
Sennheiser PXC 250
MonsterCable Beats by Dr. Dre
 More...Prices updated November 24th at 12:30am and include delivery.
iPod Connector from Car to headphone 2.5mm jack plug grd2 Portable Music (MP3, iPod etc.) 0 21-03-2007 1:31 PM
Dolby Headphone - 5.1 channel headphone surround... pointon Headphones and Headphone Amps 6 24-06-2006 6:42 AM
HDMI connector shape change braehead High Definition TV Hardware 1 04-05-2006 7:51 PM
Pioneer DVR 520H won't automatically change to 16:9 when I change onto it? Rosie DVD and Blu-ray Recorders, Recording and Media 3 28-02-2006 6:15 PM
Old 24-01-2008, 3:09 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Possible to change headphone connector?
Guys,
Excuse my general ignorance of connector terms, but I've a question for the experts out there.
I have a pair of sennheiser HD 25 SP's (My lovely wife asked around for advice on headphones and got me some for my brithday). They're great.
I have one small problem, I only use my headphones for my ipod and the connector on these things is huge (Big fat adio in style thingie). I got a converter to an ipod type connector but it's loody huge as well, I now seem to have these great size closed headphones with a bloody big connector going into my ipod, which is just too awkward to sit in a pocket, comes loose and generally is annoying.
Is it possible to chop off the end bit and get it rewired, and if so any suggestions where I would go to to get something like this done (I live in London)?
Many thanks.
snowbhoy is offline   Reply With Quote
Old 24-01-2008, 7:59 PM   #2 (permalink)
cribeiro's Avatar
Thanks: Gave 142, Got 268
Re: Possible to change headphone connector?
Yes, that can be done. You just need to get the parts, something like this (a gold-plated one would be better, but I cannot find any)
http://electrical.playrecord.net/con....p1021507.html
and use a soldering iron. I do not know in which place you could get it done, but at least I wanted to let you know it is possible
In any case, it is an easy task (10min work) and should not cost you that much.
Wish list: Harmony 1, WooAudio6, a detached house
cribeiro is offline   Reply With Quote
Old 24-01-2008, 8:28 PM   #3 (permalink)
trailer's Avatar
Thanks: Gave 29, Got 137
If you do consider doing it yourself you will need to know which core is which on the old lead so you get the lwft and right channels the correct way.
Naim CD5x FC2 NAC202 NAPSC HiCap NAP250.2 B&W 804s Hydra Q4
Samsung 40UB8000 Oppo BD-83MR SkyHD AVR350 B&W 601s2 HTM4s QAV System
iPod iPhone Westone UM-2 Apple TV ReadyNAS Duo Airport Express Monarchy DIP Beresford 7510SE/7520SE iBasso D2-Boa
trailer is offline   Reply With Quote
Old 25-01-2008, 11:44 AM   #4 (permalink)
per-Sony-fied's Avatar
Thanks: Gave 47, Got 106
FYI snowbhoy (if your wondering how), the easiest way to do this is chop off the end plug with a centimetre or two of wire left (as the end plug is moulded) and strip the wires back to copper & then with a meter check for continuity between each wire & contact pin.
Hey it's not much of a crime, I saw it liked it so I stole the damn avatar. Get of my back.
per-Sony-fied is offline   Reply With Quote
Old 25-01-2008, 12:28 PM   #5 (permalink)
Cheers guys,
Started the process myself - having a few issues.
Stripped the wire back no worriesd (Inc sheathing on core wires), got two leads one with red/blue one with green/grey. I thought red/blue to one and other two to other would work, getting absoultely nothing.
Any ideas?
Old 25-01-2008, 12:33 PM   #6 (permalink)
StevieDvd's Avatar
Thanks: Gave 36, Got 87
You need 3 connections. Left, Right & Ground. Is there a metal braiding around the wires - if so that's usually the ground.
Steve
StevieDvd is offline   Reply With Quote
Old 25-01-2008, 12:43 PM   #7 (permalink)
Thanks: Gave 0, Got 27
you just need to give Brian at www.sennheiserspares.com a ring (and leave a message, he will return your call!) and tell him your dilemma, he has the correct cable, i know, i got one from him!
mattski73 is offline   Reply With Quote
Old 25-01-2008, 2:01 PM   #8 (permalink)
I had one wire with a pair in each 'side'. One side with red / blue, one side with green (Or greenish yellow) and grey (Or siver).
I can get this inner case off pretty easily using a stanley knife and scrapping it off.
Now connected it up - used red/green and blue/grey - styill trying to figure out if they sound ok or not. If I put my connector in all the way they sound very washed out - but I have a case in my ipod which stops it going al the way so sound is fine.
Comparing them to some regular headpones I have, and they have a better base etc but don't sound quite as rich, if that makes sense. Sure if I just picked them up they'd sound fine 0 the difference just the difference between the headsets rather than my solder?
Old 25-01-2008, 2:04 PM   #9 (permalink)
So you replaced the whole cable - how? Assuming at the earpiece part itself?
Old 25-01-2008, 6:08 PM   #10 (permalink)
cribeiro's Avatar
As per-Sony-fied suggested, you need to use a multimeter to check where goes which cable.
The original plug has 3 regions on the tip. On the chopped end, you should still be able to reach the core of each cable (red, blue, green and grey). Set the multimeter to measure ohm (lowest ohm region is fine), and check first if the device is working by joining both ends of the probe tips of the multimeter (you should get near zero ohms).
Apply one of the probe tips to the first region of the plug end. Touch each core of the chopped end with the other probe tip, and see which one(s)* give you near zero ohms. Note it down (with a drawing, to avoid confussion).
Do the same for the other two regions of the plug end, and now you know which is which.
EDIT: when you solder, apply heat to the wire and plug contact, then touch the wire with the tin, it should melt and run down the cable and plug contact. Do not apply too much solder, just to cover the joint. Then hold your breath, because it must dry without being moved. The result should be a smooth and gleaming surface (I am not an expert, but the experts where I work explained it to me this way...)
*One region of the plug tip will have two cables connected, this is GND.
Old 09-02-2008, 9:36 PM   #11 (permalink)
Thanks: Gave 0, Got 7
Just a thought (and too late now!) but are you sure you actually had a problem in the first place? Most Sennheiser headphones I've had have come with a 6.3mm plug which separates (by gently pulling) into two parts revealing a 3.5mm one inside.....
And according to:
http://www.sennheiser.co.uk/uk/icm.n...nes_dj_502103#
"Rugged closed dynamic headphone. Max. SPL 120 dB, frequency response 30 Hz to 16 kHz, THD < 0.4 %, nominal impedance 65 ., load rating 0.2 W. 3 m steel cable with 3.5 mm stereo jack plug and adaptor to 1 /4 ” (6.3 mm) stereo jack plug."
Stompa
Stompa is offline   Reply With Quote
Old 05-04-2008, 1:43 PM   #12 (permalink)
DEFINITIVE GUIDE TO REPLACE SENNHEISER HD 25 SP CABLE
QUATER INCH JACK WITH MINI JACK FOR PORTABLE MUSIC DEVICES
Ahh, at LAST - is always a hassle to have to register with a forum just to post one reply but it'll be worth it if it helps someone out. - I could not find this information anywhere else and since in the past ppl have helped me with various software/file and also real information on forums I had to post my solution here, even though this post is prehistoric I'm about to wake it up!
This thread is the 5th in Google for searches containing "sennheiser hd 25 sp" and "soldering" so it's probably the best place to post this.
I recieved these headphones from an uncle a few years ago and I was ****** that the jack wasn't switchable (damn you sennheiser!) though I think their new kick-ass models are switchable. I used it for a few months on the street, with a proper quarter inch to mini jack converter but it was WELL cumbersome and after a while the jack on the headphones got damaged and started to cut out a little bit. Drat. Thing is, it was more than a year later (recently) that I though (not being an electrician nor handy with such things at all): "why don't I just solder a new one on??"
First up I checked if there was a mini jack replacement cable which there was at sennheiserspares.com - but it's £25 which is bloody ridiculous.
I can buy a decent jack AND a soldering kit for less than that. So I did.
Eventually I got round to ordering this (I gotta have the best)
Neutrik 3.5mm stereo right angle plug
from
http://www.felmicamps.co.uk/products...ectorsand.html
Good old FEL Communications (thanks guys)
This really is the best mini-jack I have ever seen. Right angle too, perfect for portable audio devices.
Maplins is the WHACK!
Then I ordered a soldering kit for £12 from WOOLWORTHS(.com)
It's a good enough kit - has EVERYTHING and more
thing is, they lost it first and then I emailed them and asked them to send it again - it took 3 weeks in total (so I can't recommend their service - get from store if you can, or just use the one you have, or buy one from somewhere else)
Yo Snowbhoy, did you figure it out?
Here's the technique for replacing the quarter inch jack on the sennheiser hd 25 sp to a mini jack for laptops/iPods etc:
When I severed the cable in half (I just wanted 1.5 meters) I was annoyed to find two wires for left and right channels - four cables in total.
right channel is RED and BLUE, left channel is YELLOW and GREY
***? I though - that's when I searched for this forum.
I couldn't figure out what cribeiro was saying (above) about multimeters - way too much hard work (but cribeiro gives some good soldering advice).
Couldn't find the answer so I made an educated guess - since there are 3 points to solder on the replacement jack, one wire of each channel must carry the signal, and one wire of each channel must ground.
Goes like this:
RED & YELLOW audio channels (right and left respectively - check documentation on your replacement mini jack to check which is which when you solder)
GREY & BLUE are ground. Pretty obvious really but to those who needed a little reassurance, I hope this has been of some use.
GOOD LUCK!
chopstix is offline   Reply With Quote
cribeiro (05-04-2008)
Old 05-04-2008, 8:10 PM   #13 (permalink)
cribeiro's Avatar
Thanks chopstix, and welcome to the forums
Regarding the multimeter thing, it is pretty simple, maybe I used too many words In other words, you just check where lands each cable (technically, make a continuity check). You could as well attach a small lamp and a battery to one cable, and see with which part of the plug the lamp is on; and do this for all four cables.
It will work either way, but if you swap signal and ground in one of the channels, the sound will be out of phase. Now, I know this is very bad for loudspeakers, since you basically cancel out bass, but I don't know if it is noticeable over headphones.
I would like to add that you can also use a so-called "balanced" configuration, in which each channel "has its own ground", so to speak. In this case, the headphones sound better, but you need to have a source with balanced outputs, and an amplifier with balanced inputs and outputs.
Old 05-04-2008, 8:42 PM   #14 (permalink)
cribeiro's Avatar
For completeness, just see how to check where goes which cable in the attached picture (a picture speaks a thousand words)
change, connector, headphone
