Connecting a headphone amp to a home cinema receiver may be difficult. Headphone amps (just like speaker amps) are designed to be connected to line-level analogue outputs, typically the red-and-white "phono" sockets. To connect one to a home cinema receiver the receiver will have to have line- or pre-amp level outputs, you'll need to switch the receiver into stereo mode, and you'll need to find a way of deactivating the speakers while you're using it.
A better option might be to plug the headphone amp into the analogue outputs of your DVD player (if it has any).
There's quite a wide range of devices and price ranges when it comes to headphone amps. I use HD650 'phones and a Graham Slee "Solo" amp (
http://www.gspaudio.co.uk/headphonea...eamplifier.htm ), and I think it's a
great combination, but you may not want to spend several hundred pounds.
I would strongly urge you to audition any device you're thinking of buying and compare it directly to what you have; you may be lucky enough to own a receiver or amp that already has good headphone output, in which case the improvement with a dedicated amp may be rather small. As I said, I use a headphone amp myself, and I think it's a worthwhile investment, but I also think there's a tendency among audiophiles to exaggerate the importance of using one; the improvement may be quite subtle (unless you're comparing it to something that's powered by batteries).
