| Sound Quality
Hi, i recentley bought a new set of headphones, the Razer Barracuda HP-1 Gaming Headphones, now they are good and do sound a lot better than my old headphones, but the thing is when i turn the volume up to high i start to hear a crackling/buzzing noise, now this doesn't really bother me that much because when i listen to music, or play a game, the sound of the music/game drowns out the buzzing noise.
Also i havn't tried them out with that many games, but when i play multiplayer source games, so cs:source for example, if the sound is turned up to high on them menu you can just hear a constand beeping noise, now once again the ingame sound basically drowns this out but i dont think that this should be happening anyway.
I am using on-board sound, i have an ASUS P5B Deluxe MotherBoard, do you think that this might be the problem, the fact that im using on-board sound, i was thinking of getting a sound-card a while ago and if getting a sound card also solved this problem i would probably definatley get one.
So i really don't know if the headphones are faulty or not, because in the end they do sound a lot better than my old headphones but i dont think they should be doing stuff like that when turned up too high, anyway thanks for your help and cya.
Dave
