Hi all,
Should get my AKG K701 early next week, and am looking to get a second headphone amp with which to use them.
Currently I'm running a stock Little Dot 2 Tube amp, from China. Cheap enough, and once it's warmed up and the tubes have stopped ringing like bloody church bells, I'm impressed.
However, I'm now looking for another amp - something without vacuum tubes. Portability isn't an issue, and I'm looking for the best sound quality I can get for £100 - and ideally quite a bit less than that, considering the LD was only £45 + P&P. Power is also not much of an issue as the AKGs are apparently 62ohm models, and my other cans (HD595) are only 50ohm.
Basically I'm going to see which works better with both cans - tube or non-tube. Then I'll probably sell both and put the cash towards a better amp. I know it's probably not the most financially sensible option, but it means getting to experience different equipment, and I think it'll be fun
Thanks in advance all!
