Noise Cancelling cans?
Old 28-09-2007, 10:54 AM   #1
3,056, Level: 13
Points: 3,056, Level: 13 Points: 3,056, Level: 13 Points: 3,056, Level: 13
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
Thanks: Gave 3, Got 4
I need to buy a pair of noise cancelling cans.
They are for use in a dental surgery by patients. Thus they need to be On ear rather than over ear or in ear.
There used to be a company that produced a noise cancelling box into which you could plug any headphones, but I can't seem to find anything like that at the moment - anyone got any suggestions?
Alternatively, can anyone reocmmend a set of cans with effective noise cancelling? They need to be not too expensive (£50ish). I have been looking around, and there appear to be some Senseisers (sp?) or some called Plane Quiet NC7 which look good, but I am unsure. I don't want to spring for Boses, due to the risk of damage...
vk2003
Old 28-09-2007, 1:29 PM   #2
12,048, Level: 26
Points: 12,048, Level: 26 Points: 12,048, Level: 26 Points: 12,048, Level: 26
Thanks: Gave 42, Got 92
Re: Noise Cancelling cans?
How about the sennheiser PCX250 ?
http://www.amazon.co.uk/Sennheiser-P...986152&sr=8-11
Old 28-09-2007, 8:35 PM   #3
3,056, Level: 13
Activity: 2.1%
Thanks Matt
I was looking at those or the PXC300. Suspect that as most of the sounds in a dental surgery are high freq, the difference between them will be minimal so the 250 will do fine.
vk2003
Old 28-09-2007, 9:45 PM   #4
Johnnash
Posts: n/a
Sennheiser are good, but for a surgery Bose Quiet Comfort 2 would be superb. These are completely over-ear and have their own battery power. Bose Quiet Comfort 3, which are smaller and on-ear, are supplied in first and business class on BA & Virgin, but the 2 series are cheaper and just as good.
Old 29-09-2007, 10:59 AM   #5
Eminent Member
Tejstar's Avatar
126,891, Level: 86
Points: 126,891, Level: 86 Points: 126,891, Level: 86 Points: 126,891, Level: 86
Thanks: Gave 408, Got 993
Originally Posted by Matt Horne View Post
I have these and they are a good set of cans if noise cancelling is switched on, they sound pretty crap without it though. Be aware though that they won't get rid of all sounds, just ambient noise.
Old 30-09-2007, 10:32 AM   #6
5,163, Level: 17
Points: 5,163, Level: 17 Points: 5,163, Level: 17 Points: 5,163, Level: 17
Thanks: Gave 13, Got 0
Originally Posted by vk2003 View Post
Thanks Matt
vk2003
Double check the tech specs carefully before you buy. If I understand it correctly, noise cancelling headphones are best at removing low frequency sounds, like the drone of an aircraft engine. A squealing dental drill may not be cut out effectively.
Old 30-09-2007, 10:29 PM   #7
3,056, Level: 13
Activity: 2.1%
The high frequencies in the surgery are a problem with any noise cancelling cans.
However, the type of treatment when I will be using these involve very little drilling except at the start of the appointment; the rest of the time, things are pretty quiet.
I want to avoid the over ear cans as they are quite bulky, and so may get in my way; I also want to be able to check the patient is OK periodically, so that is why the on ears are preferable (that is my perception anyway!) Thus the Bose 3's would be preferable to the 2's, but just a little too expensive; things tend to get knocked and dropped by third parties, and thus breakages can occur relatively easily - I would be gutted to spend £300 on some bose cans, and then find they break a short while later.
I reckon the Sennheisers will probably do the job, but are cheaper; I accept that there are better, but for the same price?
Any other suggestions as to cans gratefully received though...
Old 07-10-2007, 9:22 AM   #8
12,048, Level: 26
Audio-Technica ATH-ANC7
Can be got for about £70 off ebay.. think I am going to get a pair of these :
http://www.soundandvisionmag.com/av/...eadphones.html
Cheapest I have found over here is about £100
Old 08-10-2007, 4:12 PM   #9
chrisgeary's Avatar
9,844, Level: 23
Points: 9,844, Level: 23 Points: 9,844, Level: 23 Points: 9,844, Level: 23
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Thanks: Gave 172, Got 97
Matt.. I would be interested to know what your opinion is once you have had them a while.
Old 09-10-2007, 9:11 AM   #10
12,048, Level: 26
Well I've bought some.. just got to wait for them to arrived and get through the POstal strike
Old 22-10-2007, 11:47 AM   #11
7,722, Level: 20
Points: 7,722, Level: 20 Points: 7,722, Level: 20 Points: 7,722, Level: 20
Thanks: Gave 57, Got 62
If you imported them from outside EU, I wonder whether you got hit by customs. I know I did.
Good cans though, used them on a longhaul flight and SQ as well as noice cancelling was pretty good with/-out the inflight system. One big advantage over Bose, they still work (edit: as "normal" ear cans, not the noise cancelation) after the battery is finished (not that this would happen that easily).
Old 22-10-2007, 3:17 PM   #12
12,048, Level: 26
I'm still waiting.. but tbh I rarely seem to get caught... but we shall see
Old 25-10-2007, 8:05 PM   #13
12,048, Level: 26
They arrived yesterday.... lovely cans with a superb case and accessories. Work well without the noise cancelling (though quite low volume from the ipod) and then turn them on its like opening the curtains.
The Noise cancelling works so well... tried them on the commmute into london..the rythmic tone of the train just disappears and I had a very pleasant journey Also when on I cannot go to max volume on the ipod classic.. its really loud and due to the quiet really not needed.
Also used to all day at work... and hid all the computer noise/aircon nicely.. superb for getting a bit of quiet whilst working (and listening to a couple of podcasts)
Oh and no additional charge from customs.....
chrisgeary (29-10-2007)
Old 29-10-2007, 2:33 PM   #14
chrisgeary's Avatar
9,844, Level: 23
Activity: 1.3%
where did you get them from?
Old 29-10-2007, 9:14 PM   #15
12,048, Level: 26
Here you go :
http://cgi.ebay.co.uk/AUDIO-TECHNICA...QQcmdZViewItem
check all his auctions as the price seems to vary amongst them.
Real nice phones.. work so well in my office.. and on the train..
chrisgeary (30-10-2007)
Old 20-11-2007, 9:19 AM   #16
chrisgeary's Avatar
9,844, Level: 23
Activity: 1.3%
Matt,
what other phones have you owned and how do they compare?
also, is it true that the ATs leak a lot of sound - so that someone next to you will hear your music?
Old 30-11-2007, 7:09 AM   #17
2,759, Level: 12
Points: 2,759, Level: 12 Points: 2,759, Level: 12 Points: 2,759, Level: 12
I have the ANC's too. Brilliant. They don't leak any sound.
Old 30-11-2007, 3:28 PM   #18
4,139, Level: 15
Points: 4,139, Level: 15 Points: 4,139, Level: 15 Points: 4,139, Level: 15
Thanks: Gave 0, Got 8
A vote for these:
Pioneer SE-MJNS
http://www.audiocubes.com/category/H...eadphones.html
You can buy from ebay as well.
Look like the creative HN-700, but thankfully sound nothing like them, very close to my Bose quiet comfort 2 and the noise cancelling is excellent. Also they fold away and the finish is far superior to the creative one (by miles).
Powered by
 Latest popular product prices
Sony MDR-NC7
6 prices from
 £14.97 Click to show/hide the offers
Sony MDR-ZX300
6 prices from
 £17.63 Click to show/hide the offers
Sennheiser CX 300-II
8 prices from
 £32.99 Click to show/hide the offers
Panasonic RP-HTX7
3 prices from
 £28.89 Click to show/hide the offers
SoundMAGIC E10
2 prices from
 £34.99 Click to show/hide the offers
Sony MDR-XB500
2 prices from
 £39.99 Click to show/hide the offers
Beyerdynamic DTX 101 iE
1 price
 £52.24 Click to show/hide the offers
Klipsch Image S4i
6 prices from
 £59.94 Click to show/hide the offers
 Updated February 13th at 12:30am. Prices include delivery.
