Go Back   AVForums.com > Audio Electronics > Headphones and Headphone Amps
Today's price checkPowered by
Bose On-Ear Headphones
Bose In-Ear Headphones
Bose QuietComfort 3
Sennheiser RS 130
Bose QuietComfort 3
Sennheiser RS 130
Sennheiser CX 300-II
Bose Around-Ear Headphones
Sennheiser CX 400-II
Sennheiser CX 300
Sennheiser PX 100
MonsterCable Beats by Dr. Dre
 More...Prices updated November 21st at 10:30pm and include delivery.
Old 12-08-2007, 11:36 PM   #1 (permalink)
Thanks: Gave 2, Got 1
Fixing my Headphones
I have a set of stereo earphones.
The jack broke the other day, so i removed it. The cable consists of 2 ground cables, and 2 more cables, one for L and R. These have enamel on them insulating them from the ground.
I cant remove this for re-wiring without damaging the wire...
Any ideas on how i can fix the earphones?
MrBluesMan is offline   Reply With Quote
Old 13-08-2007, 12:30 PM   #2 (permalink)
StevieDvd's Avatar
Thanks: Gave 36, Got 87
Re: Fixing my Headphones
Yes,
The enamalled wire is becoming increasingly common. You basically need to burn this off to enable the solder to adhere.
Either with a lighter (a bit tricky) or using the solder iron (a bit easier) or a solder bath (easier but uses a lot of solder and not typically a diy task).
You do of course have to re-insulate any bare wiring as the enamel is the insulation (mass production economy I suppose). I'd suggest heatshrink over pvc tape.
It can be done, have done it myself and told others how to do it (no compaints so far) - but the manufacturers would say it's not a diy job and either a warranty repair of buy a new set
Steve
StevieDvd is offline   Reply With Quote
fixing, headphones
