Help needed rewiring PXC 250s with new jack
Old 10-08-2007, 8:03 PM   #1
ChrisCatch22's Avatar
2,637, Level: 11
Points: 2,637, Level: 11 Points: 2,637, Level: 11 Points: 2,637, Level: 11
Thanks: Gave 54, Got 22
My Sennheiser PXC 250 lost sound in one ear, so I decided as they were out of warranty to attempt to put a new 3.5mm jack plug on.
I have succeeded in getting sound out of both ears now, but it appears to be the same channel??? Anyone got any experience rewiring headphones?
I have soldered the red wire to the ring, and the green to the pin, with the copper wire to the sleeve. Weirdly though, I had sound in both chanels with just the red wire.
Can anyone help?
(and yes I did remove the enamelling before soldering the tips of the wires)
Old 12-08-2007, 10:27 PM   #2
2,967, Level: 12
Points: 2,967, Level: 12 Points: 2,967, Level: 12 Points: 2,967, Level: 12
Thanks: Gave 1, Got 8
Re: Help needed rewiring PXC 250s with new jack
The pxc-250's are an unservicable set of headphones.
If they are under warranty they are replaced not repaired.
If they are out of warranty they should be skipped.
Usually the wiring is
red-tip
green-ring
shield-sleeve
However the cable is designed to be unsolderable. It's usually got fiber running through it to make it almost impossible to get a good connection.
Old 28-08-2007, 7:27 PM   #3
2,637, Level: 11
Just got a reply from a Sennheiser Service team leader, after making an enquiry on their website
Chris,
You should find that there are three wires: Red, green and copper coloured.
The green will be the left signal - tip of jack
The red will be the right signal - ring of jack
The copper will be the common connection - sleeve of jack
Have soldered the wires as above and its worked perfectly. Total cost of the repair 60p for a new 3.5mm jack plug.
I did have to burn the tips of each wire to remove the enamelling before soldering them, a lighter worked well for that.
I hope this helps others in the same position, saving an otherwise servicable pair of headphones.
Powered by
 Latest popular product prices
Sony MDR-NC7
6 prices from
 £14.97 Click to show/hide the offers
Sony MDR-ZX300
6 prices from
 £17.63 Click to show/hide the offers
Sennheiser CX 300-II
8 prices from
 £32.99 Click to show/hide the offers
Panasonic RP-HTX7
3 prices from
 £28.89 Click to show/hide the offers
SoundMAGIC E10
2 prices from
 £34.99 Click to show/hide the offers
Sony MDR-XB500
2 prices from
 £39.99 Click to show/hide the offers
Beyerdynamic DTX 101 iE
1 price
 £52.24 Click to show/hide the offers
Klipsch Image S4i
6 prices from
 £59.94 Click to show/hide the offers
 Updated February 11th at 10:30am. Prices include delivery.
