Originally Posted by clearsound Please could anyone help, I have a home cinema with optical connection, and I have just ordered some Sony MDR-DS3000K inrared wireless 3.1 headphones.
My question is, if I only use the optical connection from the headphones to the home cinema, will I be able to hear anything that is not recorded in 5.1, or just 5.1 only?
Thankyou in advance, Brian. |
You'll note that these headphones have both an optical and a standard stereo phono input together with a digital/analogue switch on the base unit.
I can't remember the exact details (I've now packed the 'phones as I'm moving) but I had the 'phones connected to the optical out on my AV receiver and also connected the phono leads as I couldn't hear all sources.
As far as I recall, output from my PS3 (optical into receiver) and DVD recorder (coax into receiver) worked fine on the 'digital' setting. I think the CD (coax output) worked ok too.
My Wii is connected directly to the TV and I have a phono lead from the TV to the receiver for the TV sound. I'm pretty sure that I bought the phono lead for the headphones so that I could hear the analogue signal from the TV.
In short, you should be fine for any digital source (stereo or 5.1); but I doubt if the home cinema system will convert an analogue source and output it via the optical output.
