Originally Posted by StevieDvd The E500 is the same as the SE530 - just re-marketing and model renumbering. |
It also ships with the new, thicker black foamies. But yeah, otherwise, it's exactly the same in terms of the internals etc.
As for the rest of them, I'd wait. Once the reviews are out, you'll see how good/bad they are in comparison to the old ones. Depending on the reviews, your option will then be to buy the news ones if the reviews are positive, and if the reviews are negative or "these sound the same as the old ones" then you'll be able to pick up a bargain on some of the older range, safe in the knowledge that Joe Public needs to have the latest and greatest while you're able to buy the same/a better level of performance for half the price and spend the rest on CDs!
Either way, you win. I'd wait a little. Keep an eye on Head-Fi.org for the reviews.
