Go Back   AVForums.com > Audio Electronics > Headphones and Headphone Amps
Today's price checkPowered by
Bose On-Ear Headphones
Bose In-Ear Headphones
Sennheiser RS 130
Sennheiser CX 300-II
Sennheiser RS 130
Bose Around-Ear Headphones
Sennheiser CX 400-II
Sennheiser PX 100
Sennheiser CX 300
Sennheiser PXC 250
MonsterCable Beats by Dr. Dre
 More...Prices updated November 24th at 4:30am and include delivery.
Old 15-02-2007, 8:54 PM   #1 (permalink)
Monkey99's Avatar
noise cancelling\isolating headphones
Well need a bit of help.. I work in IT and am always in machine rooms - always noisy and am sure it damages my ears. I also fly quite often and would be good to have a quiet seat so I can
I presently have some Skull Candy Smokin Earbuds, but they keep coming loose in my ears.. what I would like is some replacements and have a budget of up to £50... either finding some earbuds that have a better fit or going for some larger ones - any recommendations?
thanks
Monkey99 is offline   Reply With Quote
Old 16-02-2007, 4:20 AM   #2 (permalink)
Thanks: Gave 14, Got 49
Re: noise cancelling\isolating headphones
thanks
Get a sound meter into the server room or ask them to tell you what the sound level is as you can get a hum in the ears if too loud (I too work in IT). Mate you can afford an extra £15 I know you can Go for some shure e3c I hear they are on Amazon for this price. They will isolate the noise and have buds of varying sizes. I think you have to think of quality and support for the ear phones and shure are very good.
I'm very happy with the stuff I've got but I'm sure if I upgrade just a bit it won't hurt (and so the cycle begins ......) it's too late for me save yourselves
Reano is offline   Reply With Quote
Old 16-02-2007, 12:04 PM   #3 (permalink)
jason44mag's Avatar
Thanks: Gave 233, Got 33
I use the senns cx300, not sure if they would do the job in your situation but when im jogging i cant hear the cars coming
jason44mag is offline   Reply With Quote
Old 16-02-2007, 9:23 PM   #4 (permalink)
They may not look as fashionable as the Skull Candy 'phones but the Senn HD280 Pros are exceptionally good for the price.
Holden4th is offline   Reply With Quote
Old 16-02-2007, 10:22 PM   #5 (permalink)
Monkey99's Avatar
What about the e2c's they any good..? or are the e3c's much better at isolating the sound?
Old 17-02-2007, 12:38 AM   #6 (permalink)
Thanks: Gave 11, Got 0
[url]http://www.head-fi.org/forums/forumdisplay.php?s=&forumid=2
pablodablo is offline   Reply With Quote
Old 27-02-2007, 11:40 AM   #7 (permalink)
Thanks: Gave 0, Got 2
thanks
If you wanted to save a load of money go for the Creative Labs HN700 ~£30
I think lowestontheweb were the cheapest for these a couple of weeks ago.
You could get the Senns PXC250 for £50 from ebay or the PCX300 for £75
If you wanted to spend a bit more I did read that the Panasonic RPHC300ES are supposed to be very good and you get a leather case to keep them in. They are sold for around £100 in the UK. Just had a look on Ebay and you can get them from the USA for ~$120 which is about £65.
HTH
thetargetarcher is offline   Reply With Quote
Old 08-03-2007, 12:10 AM   #8 (permalink)
Thanks: Gave 0, Got 6
Thumbs up Re: noise cancelling\isolating headphones
Hey there monkey 99,
The sure E2c and 3c's isolation is about the same, or marginally different. The only thing you're paying for is the tuned port technology which delivers a better bass. However there's a rather distinct price gap between the E2c's and E3c's. However if you wanna isolate sounds of whizzing aircon, pc hdd's, keyboard tap, mice clicks, static flickers, printers printing, keyboard slides open and shut I'd choose the shure's hands down, along with a few other companies that has similar products,
Etymotic Er6i (£99 on apple.com but can be bought for 75 at headphoneworld.com)
ultimate ear super fi 3 pro, super fi 4 pro.
Ultimate ear Metro
Derek.
drlau9 is offline   Reply With Quote
cancellingisolating, headphones, noise
