| Re: fixing Sennheiser PMX 200
Luckily it's a simple answer. the wires are coated with a varnish like substance which provides the insulation between the left/right/ground.
To solder this you'll need to burn off the coating with a hot soldering iron, a solder pot or a lighter/match. be careful of course and don't burn too much.
As you won't be able to insulate the re-connected wires with the same substance you'll need to cover any joints with heatshrink or the like so the wires are not touching each other and shorting out.
Regards
Steve
