| Re: Sony EX90 vs. Sennheiser CX300 - any opinions?
The EX90s do offer a genuine upgrade in sound quality to all of the basic model 'in-ear' type... from the likes of the JVC HA-FX55 right up to the Panasonic HJE70.
However if you need any isolation at all you can write off the EX90, as they let in a lot of sound althogh they don't leak sound that badly (but they do). They're very secure and comfy to wear, probably the most comfortable 'goes in ear' phone available. The problem is that you have to ask yourself what is the point of them going in the ear canal when there's zero isolation.
While the EX90's are notably better than the likes of the CX300, EX71, etc, headphone wise in terms of sound quality the EX90 is slightly trounced by the ~£15 Koss KSC75 clipphones (and while the Koss is superb value, it's not the giant-killer that some say it is). Since both offer no isolation at all they are directly comparable. Not quite worth it in my opinion because you can get more practical portable headphones for the same amount, but some might find the combination of discreet cool looks in an earphone format, excellent comfort and half decent sound quality - even if offset by the lack of any isolation - beguiling enough to buy it.
