Broken headphones, help!!
Old 11-09-2006, 9:18 AM   #1
6,584, Level: 19
Points: 6,584, Level: 19 Points: 6,584, Level: 19 Points: 6,584, Level: 19
Thanks: Gave 15, Got 11
I've managed to break the wire connecting my senny PMX200s to the 3.5jack, just before it enters the plastic connector. I can't take going on the tube without headphones!!!
Is there anyway I can get this fixed? I've only had them 4-5 months, the phoes themselves are fine...
Please help!!!
Old 11-09-2006, 9:29 AM   #2
3,328, Level: 13
Points: 3,328, Level: 13 Points: 3,328, Level: 13 Points: 3,328, Level: 13
Thanks: Gave 7, Got 36
Re: Broken headphones, help!!
Hi,you should be able to get a 3.5mm jack from Maplins etc.Which you can solder onto the wire ends etc.You might have to be careful thou as some of the thin wires seem to only to be insulated from each other by one wire being lacquer coated.You should'nt lose much cable lenght if the break is near the connector.
Cheers BOB
ps Jack might be fatter thou(plastic bit),so check it will allow you to fully push home the jack into your music player.You can sometimes file/remove some of the plastic if its causing any probs.
Old 11-09-2006, 11:03 AM   #3
StevieDvd's Avatar
7,088, Level: 20
Points: 7,088, Level: 20 Points: 7,088, Level: 20 Points: 7,088, Level: 20
Thanks: Gave 38, Got 152
Sennheiser are very good normally so I'd suggest you contact them first, they may just replace them for you.
Old 14-09-2006, 6:58 PM   #4
russellhclark
Posts: n/a
travel by bus?
Powered by
 Latest popular product prices
Sony MDR-ZX300
7 prices from
 £17.63 Click to show/hide the offers
Sennheiser CX 300-II
8 prices from
 £32.99 Click to show/hide the offers
Panasonic RP-HTX7
3 prices from
 £28.89 Click to show/hide the offers
SoundMAGIC E10
2 prices from
 £34.99 Click to show/hide the offers
Sony MDR-XB500
2 prices from
 £39.99 Click to show/hide the offers
Beyerdynamic DTX 101 iE
1 price
 £52.24 Click to show/hide the offers
Klipsch Image S4i
6 prices from
 £59.94 Click to show/hide the offers
AKG K450
2 prices from
 £97.87 Click to show/hide the offers
 Updated February 11th at 2:30am. Prices include delivery.
