New CDP for HD650
Old 14-03-2006, 9:55 PM   #1
4,921, Level: 16
Points: 4,921, Level: 16 Points: 4,921, Level: 16 Points: 4,921, Level: 16
Thanks: Gave 4, Got 0
New CDP for HD650
I have ordered a Graham Slee Solo monitor class headphone amplifier to use with my Sennheiser hd650. Now I need a CDP. My budget is about £400. Any suggestions?
Old 15-03-2006, 9:57 AM   #2
5,454, Level: 17
Points: 5,454, Level: 17 Points: 5,454, Level: 17 Points: 5,454, Level: 17
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 14, Got 54
I personally like Marantz if you can find a 63 ki signature (several years old now) you may find that the headphone out on some of the marantz are really good too Also some Teac models are pretty good for small sized CD players. Cyrus 6 series maybe within your budget too or maybe a cheap pioneer like 565a and then get it modified. This way you get a player that can play DVD's, DVD-audio and SACD for about £100 or less. Then get the superclock mods and 2 channel upgrade (off eBay) for about £300 and you have a good player as it can oversample to 192k.
maxipaxi (15-03-2006)
Old 15-03-2006, 8:27 PM   #3
6,811, Level: 19
Points: 6,811, Level: 19 Points: 6,811, Level: 19 Points: 6,811, Level: 19
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 88, Got 190
Most CD players at that price are much of a muchness IMO.... but going second hand for a good name CD player would prove a prudent move, you might get something from Naim, Rega or Exposure, for example.
Old 15-03-2006, 9:49 PM   #4
4,921, Level: 16
mmmh, I think I might hold on to my old TECHNICS SL P777 (very old but still faithful) a little while longer and double my budget, then go for something (second hand) reasonably good.
PS: My Solo hasn't arrived yet
Old 16-03-2006, 7:17 AM   #5
5,454, Level: 17
Activity: 1.7%
Maxi have you been on eBay for £400 you can get a lot hence some of the suggestion above
for example NAIM CD2 was £2000 originally about 6 years back now £400
Roksan Kandy KC1 CD player buy now £400
Audio Note UK CDT-1 £400
AUDIOLAB 8000 CD PLAYER (RRP £599) current £300+
MARANTZ CD17KI SIGNATURE CD PLAYER KEN ISHIWATA was £1100 now currently £310
ARCAM ALPHA 9 CD PLAYER currently £250
etc etc plus meridan transports and dacs to be honest most of these will finish around the £400 - £500 region and all secondhand.
Old 16-03-2006, 10:02 AM   #6
NicolasB's Avatar
24,275, Level: 37
Points: 24,275, Level: 37 Points: 24,275, Level: 37 Points: 24,275, Level: 37
Thanks: Gave 48, Got 553
My suggestion would be to spend a bit more. If you're using headphones and a headphone amp of that quality then a £400 CD player will be a major "weak link" in the system.
If you already own any sort of CD or DVD player with digital output then you might want to think about buying a reclocking DAC rather than a stand-alone player. The Benchmark DAC1 gets rave reviews, although it's a little out of your price range even second hand - I've seen them go for £550, though. That particular device can also double up as a headphone amp or a pre-amp (assuming the DAC itself is the sound source - I don't think it has analogue inputs).
Old 16-03-2006, 12:28 PM   #7
5,454, Level: 17
Activity: 1.7%
DAMN!!! What type of CD player should I be having then? something costing £1500 second hand with Gracie m902 The transport of Teac have one of the best reviews along side the meridan's for delivering the digital 0 and 1's. For conversion I find it difficult to beat the creative EMU sound cards or some of Terratec's sound cards from a PC.
Old 18-03-2006, 7:02 PM   #8
4,921, Level: 16
If you already own any sort of CD or DVD player with digital output then you might want to think about buying a reclocking DAC rather than a stand-alone player. The Benchmark DAC1 gets rave reviews, although it's a little out of your price range even second hand - I've seen them go for £550, though. That particular device can also double up as a headphone amp or a pre-amp (assuming the DAC itself is the sound source - I don't think it has analogue inputs).[/QUOTE]
What?!?... I didn't get any of that, sadly I am not very good ...well, ok lets face it I am absolutely crap, a complete useless...I'm sure you got the message: I am not very knowledgeable in this field, and I just about know what a digital output is, what the .... is a reclocking DAC? Will I need to obtain a fire-arm licence to carry one of those ,"That particular device can also double up as a headphone amp or a pre-amp (assuming the DAC itself is the sound source" What?!? Does this mean that I wont be needing my SOLO any longer? And isn't the cdp the sound source? I think that it will take me some time to get all this stuff right, but thanks anyway for trying to help
Old 18-03-2006, 9:24 PM   #9
NicolasB's Avatar
24,275, Level: 37
Okay, let's go back to first principles.
What you would normally think of as being a CD player contains a number of different components, but you can usefully divide what it does into two separate functions:
1) Read the digital sound data off the disc (i.e. convert a series of little holes in the disc surface into a series of corresponding electrical pulses).
2) Convert the digital data into an analogue electrical signal (i.e. convert a series of electrical pulses into two smoothly-varying voltages, one for left and one for right).
The result of stage 2 is the output from the player (via Phono/RCA sockets, etc.) and is what you feed into the amplifier.
In some high-performance systems you actually have two separate devices performing those two functions. This is not unlike what happens when you have a DVD player feeding a home cinema processor: the player reads a digital signal off the disc, the processor decodes it and converts it into analogue signals that can then be amplified. In such a two-box device, the part that reads the disc is called the "transport" and the part that does the conversion is called the "DAC".
"DAC" stands for "Digital to Analogue Converter" and it's a general name for any sort of device that converts digital signals into analogue ones. Most CD players will have some kind of DAC built in. But you can also buy devices that are only DACs: they convert digital signals to analogue, but they aren't able to read a disc - they have nowhere you can put a disc. Instead you use a separate CD or DVD player as a transport, and take a digital output signal from the player, and feed it into the DAC, then feed the output of the DAC into the amplifier.
Now, obviously, the transport part of a CD player costs money. So, if you spend (say) £500 on something that is only a DAC, it will do a much better job of being a DAC than the built-in DAC of a £500 CD player - because in the case of an all-in-one player, the £500 is buying you the transport as well as the DAC.
The obvious question now is, does the quality of the transport affect the sound quality? The answer to that is "sometimes". But certain types of DAC produce sound whose quality is more or less independent of the transport. These are what I'm calling a "reclocking" or "rebuffering" DAC - and I don't really want to get into precisely what that means but just accept that it means they're not fussy about the quality of the transport.
Okay, so, if you already have some kind of CD player or DVD player which has a digital output, then the best value-for-money upgrade may be to buy a reclocking DAC and use your existing player as a transport.
One example of a reclocking DAC is the Benchmark DAC1, and it's a particularly good value example, which sounds as good as DACs costing two or three times the price, and as good as all-in-one CD players costing 5 or 6 times the price. As I said before, this device is also capable of functioning as a headphone amp and as a pre-amplifier (i.e you can feed the output straight into a power amp). Whether it does as good a job of being a headphone amp as your Solo does, I don't know - that's something you could only determine by trying. But, even if it isn't quite as good, it may well be good enough.
One thing it won't do is act as a headphone amp for any sound the DAC itself is not generating - I don't know if this is an issue.
Old 18-03-2006, 11:07 PM   #10
4,921, Level: 16
Wow I actually got that
Thanks for the explanation. The Benchmark DAC1 is going right at the top of my list of things to buy next. Thanks again
Powered by
 Latest popular product prices
Sony MDR-ZX300
7 prices from
 £17.63 Click to show/hide the offers
Sennheiser CX 300-II
8 prices from
 £32.99 Click to show/hide the offers
Panasonic RP-HTX7
3 prices from
 £28.89 Click to show/hide the offers
SoundMAGIC E10
2 prices from
 £34.99 Click to show/hide the offers
Sony MDR-XB500
2 prices from
 £39.99 Click to show/hide the offers
Beyerdynamic DTX 101 iE
1 price
 £52.24 Click to show/hide the offers
Klipsch Image S4i
6 prices from
 £59.94 Click to show/hide the offers
AKG K450
1 price
 £99.95 Click to show/hide the offers
 Updated February 10th at 7:30pm. Prices include delivery.
