Shure E2C's or Bang & Olufsen A8's?
Old 16-02-2006, 3:45 PM   #1
3,630, Level: 14
Points: 3,630, Level: 14 Points: 3,630, Level: 14 Points: 3,630, Level: 14
Thanks: Gave 10, Got 29
I have a Sony HD5s and use it primarly for the work comute by tram from Bury to Manchester. I am torn between these two sets of phones can any one give me any advice on which to go for.
Old 16-02-2006, 10:16 PM   #2
Conspicuous Member
shahedz's Avatar
13,120, Level: 27
Points: 13,120, Level: 27 Points: 13,120, Level: 27 Points: 13,120, Level: 27
Thanks: Gave 1,382, Got 722
the B&Os look great, but on sound quality alone the Shures all the way! also if you are using on the train as the Shures have various attachements to fit inside your ear they really do cut out the back ground noise. i would go for the Shures.
Old 17-02-2006, 10:32 AM   #3
Beobloke's Avatar
3,824, Level: 14
Points: 3,824, Level: 14 Points: 3,824, Level: 14 Points: 3,824, Level: 14
Thanks: Gave 4, Got 58
Personally i can't stand anything stuffed in my ears, and most in-ear phones won't stay there anyway, but my B&O A8's did sterling service during the 18 months or so i had a daily commute to London.
Old 17-02-2006, 11:01 AM   #4
Conspicuous Member
Ed Selley's Avatar
9,842, Level: 23
Points: 9,842, Level: 23 Points: 9,842, Level: 23 Points: 9,842, Level: 23
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 44, Got 999
This rare shot of Beobloke arriving at work goes some way to explaining his troubles with in ear phones.
Old 17-02-2006, 11:25 AM   #5
Kazman's Avatar
20,625, Level: 34
Points: 20,625, Level: 34 Points: 20,625, Level: 34 Points: 20,625, Level: 34
Thanks: Gave 281, Got 125
I have the A8s as well, but rarely pick them up now, I only use my jukebox at work, as I no longer commute on the tube, and there I use my bose QuietComfort2 headphones (which are superb!!).
The A8s are very good for their size, built so well! I did find them a bit painful at times though, but that is probably because the back of my ears are awkwardly shaped (no, NOT like that picture posted above ).
The eShures have a very good reputation though, so it may be a case of going to the stores to have a listen, both are great phones, you should be happy with either.
Old 17-02-2006, 11:31 AM   #6
Beobloke's Avatar
3,824, Level: 14
Old 17-02-2006, 12:41 PM   #7
3,630, Level: 14
Thanks guys. I have used previously sony 81's but had the wire melting problem happen. So I am use to the ear canal type earphones. But I'm not sure if the specific way you wear the E2C's appeals its seems at lot of faffing around.
Still in a dilema.
Old 17-02-2006, 8:26 PM   #8
5,621, Level: 17
Points: 5,621, Level: 17 Points: 5,621, Level: 17 Points: 5,621, Level: 17
Thanks: Gave 3, Got 10
Once you've sorted out the correct ear-bung to use, fitting and comfort really isn't a problem. Also, once in they don't full out, the suction seal see's to that!
Probably totally put you off now...
Old 18-02-2006, 7:36 PM   #9
3,630, Level: 14
Not so much the ear buds but the trailing the cable around the back of your ear thing.
Old 23-02-2006, 4:20 PM   #10
ether0606
Posts: n/a
Hi my tuppence worth. I bought the Shure e2c couple of weeks back, and couldn't bear to fit anything in my ear apart from the foam pads. But now, after two weeks, I have replaced the foam pads with the transparent supple ones. Lo & behold, they go in so well. Probably my ear has grown bigger after plugging in the foam pads for 2 weeks ; and the sound is fantastic, the bass booms, and my h340 is pure rock n roll. I am a Shure fan, gimme one anyday. Cheers.
Old 26-02-2006, 7:51 PM   #11
Stewtheking
Posts: n/a
Another vote for the Shures. I had the A8, and decided to try the e2c. I was blown away by the isolation, and ended up selling the a8 because i couldn't go back.
It is fantastic how on my commute, i can see the screaming children, and see the anguish of others, but all i can hear is Norah Jones whispering her sweet nothings into my ears... bliss...
Old 03-03-2006, 3:06 PM   #12
kevH's Avatar
8,479, Level: 22
Points: 8,479, Level: 22 Points: 8,479, Level: 22 Points: 8,479, Level: 22
Thanks: Gave 25, Got 44
Another vote for the Shures here to ive got the E4's and theyre superb even tho im a devout B&O fan and have quite a bit of their gear the Shures win hands down over the 8's everytime
Powered by
 Latest popular product prices
Sony MDR-ZX300
7 prices from
 £17.63 Click to show/hide the offers
Sennheiser CX 300-II
8 prices from
 £32.99 Click to show/hide the offers
Panasonic RP-HTX7
3 prices from
 £28.89 Click to show/hide the offers
SoundMAGIC E10
2 prices from
 £34.99 Click to show/hide the offers
Sony MDR-XB500
2 prices from
 £39.99 Click to show/hide the offers
Beyerdynamic DTX 101 iE
1 price
 £52.24 Click to show/hide the offers
Klipsch Image S4i
6 prices from
 £59.94 Click to show/hide the offers
AKG K450
2 prices from
 £97.87 Click to show/hide the offers
 Updated February 11th at 7:30am. Prices include delivery.
