The X-Can v3 is an acquired taste. For sure it has a smooth set of mids and a definite noticable effect on the sound, but if you like a lot of bass driven music its probably best to stay away.
I've used the v3 paired with the 650 and while the combination was not bad, and clearly not offensive, I always craved for something a little harder hitting. I currently use and favour an ANT Amber however, i think maybe this is not quite the ideal amp for the 650, but then I was never that keen on the 650's personally so I sold them.
I know its a US based amp, but I'd be inclined to recommend a Gilmore Lite from headamp.com. I think this is one of the better amps around sub £200, and will deliver a clean, detailed, fast and lively sound to the HD650.
