Ok...take a look at the Creek,also used MF X-cans,and possibly some of the DIY amps if you feel ok with a soldering iron.
Of those,the MF will probably serve you best if you can find a decent used one,but do a search here,and you may turn up some more suggestions to fit the budget as well.
Being honest,I feel that most decent dynamic phones benefit form a good headphone amp,and if you are prepared to spend over £100,you should find something to suit your requirements.
Almost forgot...the Rega Ear.
