10-11-2005, 11:10 AM
#1 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | headphone amp question /sennheiser pmx200 headphones
just bought some sennheiser pmx 200 neckband headphones phones, quality portables, i use them with my mp3 player for the gym and running so needed robust quality gear as i have tried loads of different types, in ear, over ear , buds and they have all had shortcomings, mainly in staying in position, or as with my phillips over ear the sweat in my ears was building up causing a barrier between the headphone and my ear, disrupting the sound, i know for a fact the sennheisers can deal with sweat as my hd25-1's have withstood 5 years of djing in hot clubs , these headphones have a neckband and over ear clips which hold the phones perfectly in place , just a nice amount of pressure so as not to be worrying about them slipping and the sound out of them is excellent, my question is i now want a headphone amp no more than £50 as i am on a budget, i also need it as small as poss and to be able to withstand being taken out running , can anybody help thanks
10-11-2005, 11:25 AM
#2 (permalink)
| | New Member
btw they are 32ohm are the boostaro prducts any good?
10-11-2005, 1:36 PM
#4 (permalink)
| | Prominent Member
Thanks: Gave 789, Got 425 |
i made my own chu moy amp. it was simple and the is a massive improvement on the sound quality. i recommend them, also if you dont want to go through the hassel of making it you can always buy one, read made
__________________ Linn Kolektor pre amp & LK140 amp,Genki,Sony MD MDS JE510,Sonos ZP80 + CR100,Ariston RD-40 turntable,TDL RTL3 ,Samsung32R87, Yamaha YSP-1000,Panasonic PT-AX100E projector,Toshiba HD-E1 ,Sky HD, PS3,Harmony 885 |
10-11-2005, 6:24 PM
#6 (permalink)
| | Prominent Member
to be honest i'm not too sure. reason being is i havnt heard the shellbrook. the circuit design looks very similar. but the build on the shellbrook looks outstanding, i personally would experiement with the shell brook seeing as its only just over £30,
10-11-2005, 6:28 PM
#7 (permalink)
| | New Member
its £30 more at todays exhange rate its about £65 - £70 , do you reckon its worth a go still
10-11-2005, 9:41 PM
#8 (permalink)
| | Prominent Member
thats quite a lot. to be honest its more than i would gamble on something with out hearing it, to be honest i dont think you can go far wrong with a chu moy, they are populare because they are good-and cheap. and i think if you bought it and didnt like it you could probably sell it for what you got it for. go for a chu moy see how it that goes first, i was really impressed with it!
