LOL, so your going on about bass, and then your going to buy the least bassy Shure you can buy....
Well, I'd just stick to the EX71's if thats all your after
Perhaps you should check this graph out, where you can clearly see the bass is very prominent on the E2C....
http://www.headphone.com/layout.php?...are+Headphones
Better still, check this graph out that compares the E2C and E3C, and you can clearly see the E3C has LESS bass than the E2C.
That review is a load of crap.
Why dont you try and search headfi, I doubt you'd find many opinions on there stating the Shure's lack bass - the only time I've ever heard it complained about it when they dont have them in properly.
