extending headphone cable.good or bad idea/
Old 05-01-2005, 7:46 PM   #1
ianlecompte's Avatar
4,887, Level: 16
Points: 4,887, Level: 16 Points: 4,887, Level: 16 Points: 4,887, Level: 16
Thanks: Gave 37, Got 11
as the title says really,looking at getting some cans but they all seem to have quite short leads,would it degrade sound quality if i was to buy an extender lead?or could i have the lead replaced with something better and longer if i took them to a hifi store.or should i go for something like the sennie 45 wireless?they seem to go quite cheap on ebay,will be used for music and late nite gaming.
cheers
ian
Old 05-01-2005, 7:52 PM   #2
ipodstudio
Posts: n/a
cheers
ian
How long do you need it? I use this Cardas v2 cable on my Sennheiser HD650s but not becuase of it's 10ft length, but rather it's sonic qualities...
Using a headphone extention cable is not normally a problem in itself. What kind of cans are you using?
Old 05-01-2005, 11:25 PM   #3
6,811, Level: 19
Points: 6,811, Level: 19 Points: 6,811, Level: 19 Points: 6,811, Level: 19
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 88, Got 190
I use a £7 coiled extension cable off ebay, and I cant tell any difference with or without it on
Old 07-01-2005, 3:47 PM   #4
Crocodile JD's Avatar
10,056, Level: 24
Points: 10,056, Level: 24 Points: 10,056, Level: 24 Points: 10,056, Level: 24
Thanks: Gave 10, Got 20
I made my own extension cable using decent quality parts from Maplins and some low impedence microphone cable. It works a treat and does not affect the sound one jot.
Croc
Old 07-01-2005, 7:22 PM   #5
G a f f e r's Avatar
15,929, Level: 30
Points: 15,929, Level: 30 Points: 15,929, Level: 30 Points: 15,929, Level: 30
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 192, Got 341
Also made my own by canibalising a set of £50 Sony headphon es. Bit tricky to scrape the OFC coatings off the copper wires (like red and green paint/wax). Then soldered an adapter on.
Great sound (about 3 meter cable) with no obvious loss in SQ when using my sennies
Old 15-01-2005, 8:14 PM   #6
4,887, Level: 16
hi croc,that sounds a great idea,microphone cable and i guess a 3.5mm line in socket and a 1/4 jack,both in stereo,just had a look at these on maplins site,is the blue coloured cable a decent blue,any ideas?
cheers ian
Old 16-01-2005, 12:59 PM   #7
Pink Fairy's Avatar
5,532, Level: 17
Points: 5,532, Level: 17 Points: 5,532, Level: 17 Points: 5,532, Level: 17
Thanks: Gave 2, Got 1
Depending on your budget, you could try Stax phones, 3m cord length with a 5m extension available. I use the 5m every now and again and it's sonically invisible...not a cheap route but the best for actual sound quality imho.
Old 17-01-2005, 9:31 AM   #8
10,056, Level: 24
Ian
The cable I used has black sleeving. It has a core which is sheilded from an outer braid. I used this because it was advertised as low impedence which I thought might be best because of the length involved. The ends are both 1/4" jack, one female the other male, both with spring type strain relief. The plug is gold plated, but I'm not sure I could get gold plated in the socket. It's been a while so can't remember part numbers now.
HTH
Croc
Powered by
 Latest popular product prices
Sony MDR-NC7
6 prices from
 £14.97 Click to show/hide the offers
Sony MDR-ZX300
6 prices from
 £17.63 Click to show/hide the offers
Sennheiser CX 300-II
8 prices from
 £32.99 Click to show/hide the offers
Panasonic RP-HTX7
3 prices from
 £28.89 Click to show/hide the offers
SoundMAGIC E10
2 prices from
 £34.99 Click to show/hide the offers
Sony MDR-XB500
2 prices from
 £39.99 Click to show/hide the offers
Beyerdynamic DTX 101 iE
1 price
 £52.24 Click to show/hide the offers
Klipsch Image S4i
6 prices from
 £59.94 Click to show/hide the offers
 Updated February 11th at 5:30pm. Prices include delivery.
