£100 Headphones
Old 04-11-2009, 10:01 PM   #1
2,411, Level: 11
Points: 2,411, Level: 11 Points: 2,411, Level: 11 Points: 2,411, Level: 11
£100 Headphones
Hello all,
I currently have some Sennheiser HD202's and they sound fantastic. But i'm looking for a bit more audiophile level. I want closed back headphones and I think noise canceling would be a benefit, even though I don't travel, I love having the sound completely blocked out.
Stereo really, not interested much in this 5.1 stuff.
Thanks a lot,
Matt
Edit: Just had a look around and the Sennheiser PXC-350 look very nice. Can also be had for £89.99. Tempting!
Old 04-11-2009, 11:00 PM   #2
tudj's Avatar
4,086, Level: 15
Points: 4,086, Level: 15 Points: 4,086, Level: 15 Points: 4,086, Level: 15
Thanks: Gave 36, Got 84
Re: £100 Headphones
You need to take into account whatever it is you will be using the headphones with.
For example; it's not really worth spending £100 on a pair when you'll be using them with 128kb MP3's on an iPod etc.
So, what will you be using these headphones with?
About the noise cancellation - I think you'd be better off just getting a normal pair of closed headphones, most offer good/great sound isolation. Those with active noise cancellation won't sound quite as good at the same pricepoint.
Old 05-11-2009, 7:34 AM   #3
2,411, Level: 11
Re: £100 Headphones
128kb MP3's? I said audiophile god dammit! The absolute minimum for me is 320kb MP3's. It'll be used on my Sony Walkman MP4 player, my computer, TV and my Xbox. So I need a general all rounder I think.
Any suggestions? Thanks.
Old 05-11-2009, 9:49 PM   #4
2,411, Level: 11
Re: £100 Headphones
Sorry for the double post, but these can be had for the same price as the PXC 350's, would these be a better bet?
Sennheiser UK - HD 380 Pro
Old 06-11-2009, 12:55 AM   #5
Drubbing's Avatar
3,305, Level: 13
Points: 3,305, Level: 13 Points: 3,305, Level: 13 Points: 3,305, Level: 13
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 1, Got 146
Re: £100 Headphones
Headphones don't do it all by themselves. if you want something resembling high quality sound, you won't find it with good headphones, if paired with average sources like PC sound-card, MP3 players and games consoles.
If you're going to stick with basic sources, you don't want to overspend on phones.
Wireless and noise cancelling are technologies you have to pay for, in lieu of SQ, none of the models with this tech provide high quality sound.
Old 06-11-2009, 1:12 AM   #6
wicker_man's Avatar
3,757, Level: 14
Points: 3,757, Level: 14 Points: 3,757, Level: 14 Points: 3,757, Level: 14
Thanks: Gave 105, Got 60
Re: £100 Headphones
You could consider the Denon AH-D1001, they are available in John Lewis stores for demoing, but available online for about £90.
Old 06-11-2009, 11:32 AM   #7
Bonessi's Avatar
6,257, Level: 18
Points: 6,257, Level: 18 Points: 6,257, Level: 18 Points: 6,257, Level: 18
Thanks: Gave 391, Got 258
Re: £100 Headphones
I'm presuming you want closed back ones if used on your mp3 player. If you don't mind open back ones (if using at home and want a larger soundstag for your xbox I recommend the Audio Technica AD700's. Very comfy, albeit large, but they have a lovely sound from them. People say not too bassy, but there's enough for me.
When you can afford it, pair them with a nice headphone amp (I got the Astro A40 mixamp, but there's a few about) and away you go.
Old 07-11-2009, 8:50 AM   #8
2,411, Level: 11
Re: £100 Headphones
I'd really prefer some closed back ones. They're more versatile in my opinion. Sennheiser HD380 Pro?
Old 07-11-2009, 3:16 PM   #9
Drubbing's Avatar
3,305, Level: 13
Activity: 3.4%
Re: £100 Headphones
Why, the only advantage is they isolate better, which is fine if most of your use needs that.
Otherwise, open sound better for the same money.
The 380 pro I've not heard, but follows the 280 - a high isolation DJ phone with bass bias, not very comfy and pretty bland.
Old 07-11-2009, 3:46 PM   #10
3,202, Level: 13
Points: 3,202, Level: 13 Points: 3,202, Level: 13 Points: 3,202, Level: 13
Thanks: Gave 19, Got 29
Re: £100 Headphones
I made a [slightly] similar thread a while ago regarding headphones for all round usage
Beyerdynamic DT770 for all round usage
may be of some help
Old 07-11-2009, 8:35 PM   #11
2,411, Level: 11
Re: £100 Headphones
I'm a teenager and live at home still, i'm often in the lounge where someone will be watching TV, so I like to be able to focus on the audio. Plus the isolation allows me to use them on planes that I go on (infrequently)
Old 27-11-2009, 9:09 PM   #12
2,411, Level: 11
Looks like i'll be going with the Denon AH-D1001.
The sound from my PC and Xbox is actually amplified through my Sony HiFi, although it won't make a great amp, i'm sure it will make a difference.
What do you guys think?
Old 28-11-2009, 12:10 AM   #13
Drubbing's Avatar
3,305, Level: 13
Activity: 3.4%
They probably don't need amping, and from those sources adding an amp isn't a good idea, it's more likely to reveal their limitations.
No one piece of kit makes things sound great all by themselves.
Old 28-11-2009, 9:13 AM   #14
2,411, Level: 11
Oh, okay. But they're still a good choice right? The Denon's
Old 28-11-2009, 9:47 AM   #15
19,160, Level: 33
Points: 19,160, Level: 33 Points: 19,160, Level: 33 Points: 19,160, Level: 33
Thanks: Gave 10, Got 58
Also consider the Creative Aurvana Live which are rebadged versions of the Denons (I think both Denon and Creative get them from the same OEM manufacturer). Have been as low as £29.99 from Zavvi recently but now sold out. I would think you could pick them up for £50-60 though.
Old 28-11-2009, 1:17 PM   #16
2,411, Level: 11
Hmm, the Beyerdynamic DT770's are tempting.
Edit: The 80ohm ones.
Old 28-11-2009, 1:25 PM   #17
Drubbing's Avatar
3,305, Level: 13
Activity: 3.4%
Still need an amp. And the sources won't match them for quality.
Old 28-11-2009, 1:58 PM   #18
2,411, Level: 11
From what i've heard, the 80ohm's don't need an amp and sound fine at medium volume from an iPod or similar. HDMI audio out from Xbox 360 and I'll save up for a nice soundcard for my PC because i'll also need a new motherboard because i'm out of PCI slots.
Old 28-11-2009, 2:52 PM   #19
Drubbing's Avatar
3,305, Level: 13
Activity: 3.4%
From personal experience of the DT250/80, an amp will be needed to get the best out of them; amps aren't about volume, they're about providing power to move the drivers. Volume is a side effect.
My DTs sounded ok plugged in a PC/iPod, but pretty lifeless and flat sounding. They're full and rich with an amp. They don't need a lot of power/expensive amp (but not a Fiio, please!), but it makes a difference.
A good soundcard is also a must if you're going to get good phones, you don't get your money's worth otherwise.
Old 28-11-2009, 3:58 PM   #20
2,411, Level: 11
So what amp would you recommend?
Powered by
 Latest popular product prices
Sony MDR-ZX300
7 prices from
 £17.63 Click to show/hide the offers
Sennheiser CX 300-II
8 prices from
 £32.99 Click to show/hide the offers
Panasonic RP-HTX7
3 prices from
 £28.89 Click to show/hide the offers
SoundMAGIC E10
2 prices from
 £34.99 Click to show/hide the offers
Sony MDR-XB500
2 prices from
 £39.99 Click to show/hide the offers
Beyerdynamic DTX 101 iE
1 price
 £52.24 Click to show/hide the offers
Klipsch Image S4i
6 prices from
 £59.94 Click to show/hide the offers
AKG K450
2 prices from
 £97.87 Click to show/hide the offers
 Updated February 10th at 9:30pm. Prices include delivery.
