Go Back   AVForums.com > Audio Electronics > Headphones and Headphone Amps
Today's price checkPowered by
Bose In-Ear Headphones
Bose On-Ear Headphones
Sennheiser CX 300-II
Sennheiser RS 130
Sennheiser RS 130
Bose QuietComfort 3
Sennheiser CX 400-II
Bose Around-Ear Headphones
Sennheiser CX 300
MonsterCable Beats by Dr. Dre
Sennheiser RS 140
 More...Prices updated November 21st at 2:30pm and include delivery.
Xbox 360 Drive Repair - Anyone recommend a good place in UK? Jim Di Griz Xbox 360 Hardware 18 Yesterday 10:29 PM
Recommended Laserdisc player to output purist signal? LD_OUT Video Scalers, Video Processing and Progressive Scan 49 05-11-2009 2:35 PM
iPhone / iPod noise cancelling earphones, comparisons & recommendations Xstyle Headphones and Headphone Amps 8 04-11-2009 2:06 PM
TV Stand recommendations jimmymac2213 Flat Screen TV Brackets and Mounts 2 03-11-2009 12:58 PM
Do I need an HDMI Splitter, if so any recommendations? KayDavis HDMI Cables and Switches 1 01-11-2009 1:59 PM
Old 01-11-2009, 4:21 PM   #1 (permalink)
Thanks: Gave 5, Got 2
Any recommended alternative to my Shure E2c's?
Hi all.
Ive had my Shure E2c's for around 2 years although, i havent really used them to there full potential *everyday listening* as i use some cheaper sennheiser CX300's instead which when they are in my bag i dont mind if they get damaged etc. The noticable difference between these are that the CX300's have more bass but can be overpowering at times on some music then the E2c's. The Shures sound is just amazing and so natural sounding you really can tell the difference in price!
The reason im thinking of selling the E2c's is basically because of the Earwax guard system as apposed to the steel mesh of the Cx100's, Also the feel of the Shures are alittle bulkier then the CX300's which i guess are easier to fit then the Shure.
I was wondering if there was any newer alternative that did away with the earwax guards and arent as bulky as the Ec2's.
I also own some sennheiser PX100's which again for the money i cant fault and very pleased with them. So i would like another set of noise isolation shure type fitting.
Cost wise.. Probably around the same i paid for the E2c's at the time £60 ish? but willing to spend more if there alot better etc
Thanks for any recommendations you could give
Mark
Camera gear: Canon 40D. 17-40 L 4.0, 24-70 L 2.8, 70-200 L 4.0 IS USM, EFS, 75-300mm EF, Kenko 1.4, 2x converters, Kenko Extension tubes,
Compact: Canon Ixus 970i
markyb555 is offline   Reply With Quote
Old 01-11-2009, 6:13 PM   #2 (permalink)
Thanks: Gave 167, Got 344
Re: Any recommended alternative to my Shure E2c's?
I personally use Etymotic.... i have both ER6i and HF2's (the HF2's are basically the HF5's but with the addition of a microphone so i can use them as a hands free kit with my iPhone)
They cost very similar now, but the ER6i have a significant bass boost and were designed to work with portable devices. The HF5's sound stunning, they have a much better mid and top end which more than makes up for the slight lack in bass.... i guess it depends on what you listen to really, but even with heavy bass stuff, i still prefer the overall balance of the HF5's
Etymotic Research HF5 Portable iPhone and iPod In-ear: Amazon.co.uk: Electronics & Photo
Etymotic Research ER6i Isolator In-Ear Earphones: Amazon.co.uk: Electronics & Photo
TV: Samsung LE40N87BDX | Amps: Naim Nait 3R, Yamaha DSP-E800 | Sources: Naim CD5i, HTPC Blu Ray/HD DVD, Xbox 360 | Speakers: Dynaudio Focus 110, Dynaudio Audience 42C, M&K K4 Tripoles | Sub: BK Gemini | Cables: Chord Anthem, Chord Epic, Nordost 2 Flat - Pics - HTPC Build
Scott_Mac is offline   Reply With Quote
Old 03-11-2009, 7:47 PM   #3 (permalink)
thanks for the reply mate.
Its a make ive never heard much about altho have seen the name somewhere before im sure. Some of the reviews are a bit sketchy.. But i guess different peoples ears react differently and also some like alittle more bass then others some more clarity.
I guess i was sticking to what i know with the shure range.
Anyone else have any thoughts?
Many thanks
Mark
alternative, e2c, recommended, shure
