| Re: best closed headphones up to £150
I think the AKG is discontinued. Even so, it was a studio designed phone, and by reports sounded pretty crap.
All the others are pretty big, and won't travel all that well. Canal phones really would be your best bet if mostly on the move.
In addition, the Koss will need a decent desktop amp, as will the 770.
As for the Sony, anything that markets itself based on bass-a-plenty isn't going to be any good at much else.
On SQ alone, I can highly recommend the Beyer DT250 (80ohm version). But also very comfortable for long sessions, and everything is replaceable, with a detachable cable at the driver (more makers should do this) so any accidents won't see them getting binned.
Will isolate around the same as some of those you listed, which isn't huge for the tube though. Will sound very good on your hi fi and only need a little amping to get the best from them, but can go pretty well off an iPod.
