Headphone amp help please.
Old 06-12-2003, 5:33 PM   #1
Hawklord's Avatar
13,360, Level: 27
Points: 13,360, Level: 27 Points: 13,360, Level: 27 Points: 13,360, Level: 27
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 15, Got 48
Question Headphone amp help please.
After a bit of research and mulling over I'm very tempted to go for the GPS Solo MKIII headphone with the PSU1 power supply. Will this be a good match for the HD600's I received yesterday.
I must say I'm very impressed with the headphones just using normal headphone sockets on my audio equipment. How much of an improvement will there be with the solo over my current kits phono outs?
There also was a mention of a cable upgrade on the hd600's earlier in a previous thread can some one explain the benefits over the existing leads supplied and give some links to relevent products/retailers.
I'm still a bit confused as to what would be the best way to connect all my sources to the solo's inputs for best performance.
Would my denon be a better source for dvd playback over my dvd player whilst using headphones and how will this set up compare to listening to films/music conventionally?
Many thanks for any advice and pointers.
Hawklord
Old 07-12-2003, 1:22 AM   #2
NicolasB's Avatar
24,275, Level: 37
Points: 24,275, Level: 37 Points: 24,275, Level: 37 Points: 24,275, Level: 37
Thanks: Gave 48, Got 553
I use the earlier model - GSP Solo Mk II - with HD600s, and the result is very lovely indeed. I haven't, I must admit, personally auditioned any of the more expensive headphone amps for comparison. My "Solo" was bought a long while ago, while the business was still being built up, and when they were selling directly rather than via dealers, so at that time it was significantly cheaper than it is now, and comfortably outperformed everything else in its price bracket; now-price-comparable devices like the Earmax were then comparatively much more expensive.
The "Solo" has two sets of inputs, so you can connect two sources directly, or you can use some other device for switching - for example, hook the headphone amp up to the tape outputs of a pre-amplifier.
(I've found Graham Slee himself to be very approachable, btw, so if you have any significant issues, ask him).
If you're currently connecting your phones direct to a source's phono outputs, don't.
Whether you want to use your DVD player or your processor to produce a stereo signal is going to depend on the comparative quality of the two devices - it's not a clear-cut thing. For instance, I find my Bryston SP1.7 sounds as good as my Arcam DV27 for plain CDs, but for HDCDs the DV27 sounds better, because the SP1.7 dosn't understand HDCD and treats them as 16-bit only.
Old 07-12-2003, 9:47 AM   #3
Hawklord's Avatar
13,360, Level: 27
Activity: 1.9%
Thanks again NicolasB it looks as though I'm going to bite the bullet and order one.
I'm assuming it's best to go for the upgraded power supply PSU1 over the introductory model (according to reviews ) for the extra £90 or so?
It seems I'll just have to play around with different methods of connecting equipment to the two inputs to find the most suitable source for each format.
My Arcam A75+ integrated amp has a pre-amp out and a tape recording out what is the difference between these two (if any) and which would you suggest woud give the best signal?
Do headphones need running in time (as do speakers) and improve with use or are they as good staight out the box?
I did see a mention of cable upgrades for the HD600's have you any experience of these and could you give me some pointers for research purposes.
thanks again
Old 07-12-2003, 9:53 PM   #4
Senior Moderator
alexs2's Avatar
30,879, Level: 42
Points: 30,879, Level: 42 Points: 30,879, Level: 42 Points: 30,879, Level: 42
Activity: 32.6%
Activity: 32.6% Activity: 32.6% Activity: 32.6%
Thanks: Gave 388, Got 1,230
Hi there Hawklord.....I'm sure Nic knows what's coming from me here.....please also listen to the Earmax before buying any other headphone amp,and if possible have a look at the Headroom products also.
Both of these are superb,with the Headroom amps covering a very wide price range.
I've had an Earmax for a few yrs now and it's s superb amp....bags of depth,definition,and very good overall balance.
As for cable upgrades for the Sennheisers,see www.russandrews.com well worth the investment.
http://headroom.headphone.com/layout.php
Old 08-12-2003, 2:15 AM   #5
NicolasB's Avatar
24,275, Level: 37
Yeah, if you've not listened to an Earmax you probably should before you make up your mind.
It may or may not be appropriate to test out a Sugden Headmaster too, depending on situation and funds.
Yes.
At a guess, I would say that the tape output is likely to be more or less a straight feed-through of the original source signal, while the pre-amp out will be scaled down by an amount that depends on the volume control setting of the integrated amp.
Which of these is the more useful is another thing you're probably going to have to experiment to determine. The "Solo" has quite high input sensitivity, so it is sometimes a little more comfortable dealing with a signal that is at pre-amp ouput level than one that it is at source level. However, you might find find that the tape output really is a direct feed-through, while the pre-amp output has acquired some additional distortion or interference by going through the pre-amp stage, and thus that things sound better using the tape output.
Depending on how many sources you have to switch between, you might also get the best results feeding the source directly into the "Solo". (It has a fairly high input impedance, and is probably still supplied with a couple of high-quality phono splitter plugs, so you can connect it in parallel with the integrated amp inputs). But of course that means you can't use the amp as a switching device.
They can do.
No.
Try http://www.headphone.com/layout.php?...&subTopicID=31 or http://www.headphone.com/layout.php?...tID=0020080600 for a list of some of the options available.
Old 08-12-2003, 9:09 AM   #6
Illustrious Member
48,568, Level: 53
Points: 48,568, Level: 53 Points: 48,568, Level: 53 Points: 48,568, Level: 53
Thanks: Gave 884, Got 1,285
Cardas (from www.headphone.com) and RA do the cable upgrades
Old 08-12-2003, 9:50 AM   #7
sceptic's Avatar
7,010, Level: 19
Points: 7,010, Level: 19 Points: 7,010, Level: 19 Points: 7,010, Level: 19
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 12, Got 5
£160 for 2 metres? There must be an enormous improvement to justify that.
They are also charging £250 for the HD600 when thay can be found elsewhere for under £150 .
That's £410 for a headphone without an amp.
Old 08-12-2003, 10:32 AM   #8
Illustrious Member
48,568, Level: 53
I got my 600 for under £100 new . I am not justifying any cable change just pointing people to the 'options'. Jeff has just bought the Cardas to try.
sorry Alex2 missed your post!
Old 08-12-2003, 10:43 AM   #9
sceptic's Avatar
7,010, Level: 19
Activity: 2.7%
Just paid £139 for mine
It gives excellent results from a NAD350 amp. I have trouble justifying a headphone amp and £160 for a lead is not a serious consideration.
Old 08-12-2003, 1:19 PM   #10
Jeff's Avatar
18,787, Level: 33
Points: 18,787, Level: 33 Points: 18,787, Level: 33 Points: 18,787, Level: 33
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 75, Got 249
My initial thoughts are that the cable does make a big difference, the Cardas cable has completely cleaned up the bottom end of the audio, bass is a lot more refined and controlled. The Sugden amp is also very good and makes for a much smoother sound with a bit more of everything if you like, it also makes a pretty good 2ch preamp so music performance without headphones has greatly improved for me.
Old 08-12-2003, 2:06 PM   #11
Senior Moderator
alexs2's Avatar
30,879, Level: 42
Activity: 32.6%
I didn't suggest buying the headphones from RA,merely that the cable is a very worthwhile upgrade(IMHO anyway)compared to the usual wire that comes with headphones,and certainly if you're running them from a decent headphone amp.
Old 08-12-2003, 3:23 PM   #12
NicolasB's Avatar
24,275, Level: 37
Should have posted this over here first. Still, never mind....
If you're into classical music, then you simply must check out this recording. Headphone listening at its finest.
Old 08-12-2003, 5:29 PM   #13
Hawklord's Avatar
13,360, Level: 27
Activity: 1.9%
Thanks again people for all your informed advice and pointers I've certainly got a lot to think about.
I will hold off buying upgrade cables for the time being as I feel the £150 or so will be put to better use going towards upgrading my Arcam CD72t cdp to an 82t or even the 93t (I think you can upgrade to these from the cd72?).
I'll let you know what I go for and what I think when I'm in a position to do so.
regards
Old 08-12-2003, 5:47 PM   #14
NicolasB's Avatar
24,275, Level: 37
Good call. IMO, with HD600s and a Solo mk III or Earmax driving them, your CD player will be the weakest link in the chain by quite some way.
Old 10-12-2003, 3:44 PM   #15
7,119, Level: 20
Points: 7,119, Level: 20 Points: 7,119, Level: 20 Points: 7,119, Level: 20
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 6, Got 61
Has anyone managed to compare the Sugden Headmaster to the Solo MkIII or even Creek SE amps. Obviously Audio Synergy said the Sugden sould be the best partner to my new Ergo Model 2 cans but then it costs 4 times as much. I can get a demo of the Creek and Sugden but not side by side as yet.
Old 10-12-2003, 3:54 PM   #16
Senior Moderator
alexs2's Avatar
30,879, Level: 42
Activity: 32.6%
I think the Sugden is genuinely a very good amp,as it should be for the price,and also looks excellent(which isn't really something that can be said of the Earmax,which does look a little wierd and retro,even though I'm one of it's greatest fans).
The Headroom series of amps are in some instances absolutely superb and well worthy of being termed "what Krell would make if they did headphone amps",but unfortunately only available via the US.
The Creek I think is very nice and excellent value,but a bit lightweight in presentation,albeit by comparison with much more expensive amps,so a great credit to it's maker.
Old 11-12-2003, 11:09 PM   #17
7,119, Level: 20
Activity: 3.4%
Hawklord: Stefan Audio art seem to crop up as the cable upgrade for the Sennheiser 600.
Old 12-12-2003, 10:29 AM   #18
NicolasB's Avatar
24,275, Level: 37
The only comparative review I've seen of Sugden Headmaster and Earmax preferred the Sugden, but not by that great a margin, I don't think.
You might find this review of the GSP "Solo" Mk III over at TNT Audio (USA) interesting.
As my music memory has it, comparing the Solo to the Headroom [Max], I'd say the Solo Mark III is probably the more musical of the two amps.
The Headroom Max sells for $1600 in the US. The Solo costs about $800 in america, but "only" £395 here.
Powered by
 Latest popular product prices
Sony MDR-NC7
6 prices from
 £14.97 Click to show/hide the offers
Sony MDR-ZX300
6 prices from
 £17.63 Click to show/hide the offers
Sennheiser CX 300-II
8 prices from
 £32.99 Click to show/hide the offers
Panasonic RP-HTX7
3 prices from
 £28.89 Click to show/hide the offers
SoundMAGIC E10
2 prices from
 £34.99 Click to show/hide the offers
Sony MDR-XB500
2 prices from
 £39.99 Click to show/hide the offers
Beyerdynamic DTX 101 iE
1 price
 £52.24 Click to show/hide the offers
Klipsch Image S4i
6 prices from
 £59.94 Click to show/hide the offers
 Updated February 13th at 10:30am. Prices include delivery.
