Originally Posted by alphapeta I was thinking of upgrading the wiring with blackcopper V2 — will this improve the sound substantially for portable use? It'll cost around £150. I could get an upgrade to my headphone amp for that, but the re-wiring promises a wider sound stage and better instrument singularity. What do people think? Thanks, Pete. |
THat sounds like it falls into the realm of cable manufacturers BS about cables in general, and their ability to do such things, which I think is crap TBH.
It sounds like what you're getting out of the portable/HD25 is the best you're going to get. Be aware, the Fiio is as basic an amp as you can get, and will only make things louderer, not improve SQ.
I wouldn't be trusting an expensive re-wire to do very much at all. Unless you
expect it to deliver something impressive, and then it probably will.
Other things that are actually proven to make a difference will likely be a better option first. As the last poster said, (assuming you're using the HDs at home too), consider a DAC, and see how your head amp goes, as those phones shouldn't really need amping, but already having one is a bonus.
