| Re: £60 Budget for earphones..
THe Shure SE115 comes in around that price. Haven't heard them, but are quality products across the brand.
Does it have to be in ears, I would have though they'd get a bit much over long periods?
If not, I would recommend the Koss KSC 75 clip ons. They're open backed, which sounds more natural, and don't let the price fool you, they are exceptionally good.
In full size, considering you spend a lot of time indoors, and are listening a lot, I'd also recommend the Koss Porta Pro. THe Beyerdynamic DTX models are also around your price, and are very good too. At the other end, going to 90 quid if you can, are the Grado SR60. These are a great investment, just terrific sounding phones over all genres.
I think the above are all great value and very good phones and can be run off iPods etc.
I'm sure you'll get recommendations for a raft of different Sennheisers, so I'll leave them to those who've heard them. I've had the CX300 and while a big seller, I found them all bass/treble - no mids, so no warm sound.
