| Re: Definition of Open Cup Headphones and which ones for Hearing Aids
No Grado's are supra aural, they sit on the ears. Though you can get bowl pads for them, so they 'cup' the ear and sort of mimic circum aural- which is worth trying, although they may not be able to clear your ear. More portable than the ATs, but have thick cords.
It is going to be hard to find a cup that fits, yet in a small portable phone.
I recommend a visit to a good store, if one exists near you. Failing that, as most headphone-only stores appear to be online, get in touch with one, and buy from one that takes the time to give you good advice.
