3.5 million visitors each month
Go Back   AVForums.com > Audio Electronics > Headphones and Headphone Amps
Today's price checkPowered by
Sennheiser CX 400-II
Bose In-Ear Headphones
Sennheiser CX 300-II
Sennheiser CX 300
Sennheiser CX 300
Bose On-Ear Headphones
Sennheiser PXC 250
Sennheiser PMX 80 Sport II
Sennheiser PX 100
Sennheiser RS 140
 More...Prices updated November 8th at 7:30am and include delivery.
Denon DVD-2500BT owners' thread V&K Denon Owners' Forum 339 Yesterday 5:09 PM
For Sale : hd dvds Darko HD DVD Classified Adverts 10 27-05-2009 9:54 AM
What HD channels are coming bingham67 Sky HD 11 26-05-2009 3:32 PM
Old 26-05-2009, 3:16 PM   #1 (permalink)
Thanks: Gave 1, Got 3
Sennheiser HD 650 and Denon AVR-3808
Im looking for decent headphones, which I could use without buying a separate amp for headphones. Seems like there are very strong opinions against using AVR with any headphones, which I can fully understand when it comes to entry level AVRs. I still have hard time believing that Denon would whip out a mid-range AVR (3808) with headphone out that was all but useless.
Has anyone tried AVR-3808 with high impedance headphones like Sennheiser HD 650 or would I be better of with something else? Im sure I will try get headphones for test listening if possible, but it would e nice to hear some experiences and rule out bad choices if possible. I only have experience with IEM so Im sure any shared experiences would help me out.
piizei is offline   Reply With Quote
Old 29-05-2009, 6:02 PM   #2 (permalink)
Re: Sennheiser HD 650 and AV-receivers
I guess there are not so many experiences with Sennheiser HD 650 and AVR-3808. What about AV-receivers with headphones generally? Or no-one dares to admit and risk losing all that hi-fi cred gained with hard work
There's a thread in Read First -section discussing whether a separate headphone amp is necessary, but I havent found many comments from people using AV-receivers (mid-range or better). Just opinions and speculations that certain headphones require a separate headphone amp to get the best out of them.
Old 29-05-2009, 7:04 PM   #3 (permalink)
Super Moderator
alexs2's Avatar
Thanks: Gave 197, Got 659
I'd left replying to this as I don't have experience specific to the combination you have.....as you've asked about something more general,here's my 5p's worth.
I had a set of HD600s' which my son now uses,and have used these with a variety of sources and amplification,from iPods,to a very costly 300B based triode amp.
In short,getting the best out of the Hd600/650 does take not only good source material,but also a decent amplifier,and the headphone outputs of many receivers do not fall into the best category for sure.
Some are quite good,but a lot are pretty poor,and whilst ALL of them will work,the results may not be as good as you can get,but you do have to take into account the source as well,as even the best headphone amp and headphones,won't overcome a poor first link in the chain.
UVEM HCPC/TEAC VRDS/AV32R-DP/LP12 Lyra Argo/Krell KMA/B&W 805/PC-Ultra/300Bs and ESLs
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
alexs2 is offline   Reply With Quote
Old 30-05-2009, 12:33 AM   #4 (permalink)
Drubbing's Avatar
Thanks: Gave 0, Got 56
Absolutely. It's not about cred and accumulation of shiny toys to impress. Quite a number of these high end phones like the 650 will run and play on even the most basic audio equipment, like portable players - but it's not what they built for, and they won't reveal anything near their capability.
THe inherent assumption from the makers is if you're going to lay down decent money for their high end stuff, you've got the ancillaries covered. If you are going to get decent phones you really should get the equipment they need to run properly to realise your outlay, and their capability.
Headphone amps build in application-specific components, and it's not just about power output. Even in good receivers, the headphone out can sometimes be virtually a throwaway item, because it's main function lies elsewhere.
If you do go for some phones, try them out on your AVR, and see how they go, then when you're familiar with their sound, try them with your source and a good dedicated amp (assuming you've got a hifi store handy which stocks a few) and then you'll get a gauge of the AVR to drive them.
Drubbing is offline   Reply With Quote
Old 11-06-2009, 11:19 AM   #5 (permalink)
Trey4Life's Avatar
Thanks: Gave 253, Got 82
Re: Sennheiser HD 650 and Denon AVR-3808
I've listened to a set of these
on a Denon 2307 receiver and i have to say they sounded fantastic.
I'd imagine the 3808 would sound better with Sennheiser's
Trey4Life is offline   Reply With Quote
Old 11-06-2009, 11:57 AM   #6 (permalink)
Drubbing's Avatar
Just because those Panasonics sound good on it, it isn't a given that a high end phone like the HD650 would also benefit.
See Alexis' post. He's had the 650s.
Old 25-09-2009, 4:43 PM   #7 (permalink)
Grados a perfect match for AVR
After some more reading I ended up trying Grados headphones, which have very low impedance even on the higher end cans (32ohms). Bought Grado SR225 at the end. Very happy with them so far.
Compared to running them on Denon AVR-3808 and dedicated headphone amp, there is hardly any noticeable difference. The treble is slightly less controlled with Denon, which can be only noticed on very specific examples, but otherwise a great match.
So if you're planning on using headphones without a dedicated amp, Grados are definitely the way to go and worth a try. Perhaps not as comfortable as Sennheisers but comfortable enough.
Old 28-09-2009, 10:01 AM   #8 (permalink)
Thanks: Gave 14, Got 49
Re: Grados a perfect match for AVR
great stuff was gonna try my hd650 on the 4308 as that is almost the same as the 3808 but since u r happy it wont matter.... but i may try em anyway
I'm very happy with the stuff I've got but I'm sure if I upgrade just a bit it won't hurt (and so the cycle begins ......) it's too late for me save yourselves
Reano is offline   Reply With Quote
Old 29-09-2009, 9:03 PM   #9 (permalink)
Let us know how it works out for you and if possible try to demo hd650 with a dedicated amp so you can compare them to your 4308. And good luck
650, avr3808, denon, sennheiset
