What cable for 1080p at 20metres?
Old 06-02-2009, 7:03 PM   #1
4,176, Level: 15
Points: 4,176, Level: 15 Points: 4,176, Level: 15 Points: 4,176, Level: 15
Thanks: Gave 70, Got 3
I am fed-up- bleary-eyed and absolutely confused with all the manufacturer's info on their specific hdmi cables. All I really want is an honest answer to what I really believe is an honest question - which cable should I use for an 20 metre HDMI cable run? Will I need any amplification to maintain a 1080p quality signal due to the length I need or otherwise?
The length of cable I need is to run from my Onkyo to a Pioneer 5090. Please can you help to rest a really jumbled-up - fed-up and baffled mind regarding this topic????
Thanks Dave
Old 06-02-2009, 7:23 PM   #2
Assured Advertiser
Jamie S's Avatar
3,359, Level: 13
Points: 3,359, Level: 13 Points: 3,359, Level: 13 Points: 3,359, Level: 13
Activity: 8.0%
Activity: 8.0% Activity: 8.0% Activity: 8.0%
Thanks: Gave 40, Got 177
Re: What cable for 1080p at 20metres?
20m, probably best to use a HDMI over CAT5 solution.
This will ensure Full HD 1080p 48bit at this length.
You may be able to get a 20m HDMI cable, which will probably support 1080p/60hz but not the higher bitrate resolutions for deep colour source material.
We sell a HDMI over Cat5 extender for 69.99 here
Or we do a 35m HDMI cable which has a repeater built in. here at 99.99
Hope this helps.
Customer Service Team @ HD Cable Ltd
Old 06-02-2009, 7:50 PM   #3
4,176, Level: 15
Hi Jamie S
Many thanks for such a quick response. Unfortunately I don't fully understand what you mean by "20m - probably best to use a HDMI over cat 5 solution" This doesn't really mean anything to me!! Sorry for being such a newbie to this topic, but still appreciate your prompt reply,
Cheers Dave
Old 06-02-2009, 7:57 PM   #4
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
20m is well beyond the length at which anyone can say with certainty that a passive HDMI cable will work.
It might, or it might not as a lot depends on the exact equipment you are using.
Jamie is suggesting an HDMI solution that uses a cat5 cable, like those often used for computer networks, to carry the signal as these will work over longer distances.
Old 07-02-2009, 12:00 PM   #5
Assured Advertiser
Joe Fernand's Avatar
36,489, Level: 46
Points: 36,489, Level: 46 Points: 36,489, Level: 46 Points: 36,489, Level: 46
Activity: 25.4%
Activity: 25.4% Activity: 25.4% Activity: 25.4%
Thanks: Gave 205, Got 1,342
Hello daverob
HDMI.org don't mandate a maximum cable length for HDMI cables.
The latest cable Specs from HDMI.org are Standard speed (CAT1) and High Speed (CAT2).
Cables certified to meet the CAT2 High Speed spec top out at around 8m - with CAT1 cables topping out at 15m! (The Media Factory)
To achieve a 20m cable run you have a few options:
Order and test a non certified 20m cable and see if it works for you - though keep in mind it may still fall over at a later date as we see higher bit rate signals appearing.
Combine two CAT2/CAT1 cables plus an active signal extender to attain the 20m run. (Media Factory - Connect, Control and Install your Audio Visual equipment!)
Use an HDMI over Fibre optic cable - can be costly though do work very well. (RT COM USA - Product Catalog)
Use an HDMI over CAT5 solution - these units have a Send (Tx) and Receive (Rx) powered box that are connected by a single or dual CAT5 cables with HDMI Input on the Tx box and HDMI Output on the Rx box. (The Media Factory)
Joe
PS Forgot to mention Active cables - like the CAT1 and CAT2 cables these use copper conductors though this time the cable assembly includes an active repeater (usually at 15m) that is self powered.
They can work OK though you can run into EDID and HDCP issues and unlike using two cables plus an external Extender you don't have the option to try a different Eepeater that may not have the same EDID or HDCP issues. (http://www.bettercables.com/hdmi-cable.aspx)
daverob (08-02-2009)
