hdmi to scart
Old 30-06-2008, 3:44 PM   #1
2,333, Level: 11
Points: 2,333, Level: 11 Points: 2,333, Level: 11 Points: 2,333, Level: 11
hdmi to scart
I have a sony plasma tv which has no hdmi connection. I need to connect the hdmi port on my sky hd box to a scart or component connection on my tv.Any ideas?There are no other connections on the sky box !
Old 30-06-2008, 4:07 PM   #2
29,413, Level: 41
Points: 29,413, Level: 41 Points: 29,413, Level: 41 Points: 29,413, Level: 41
Activity: 43.2%
Activity: 43.2% Activity: 43.2% Activity: 43.2%
Thanks: Gave 175, Got 1,419
Re: hdmi to scart
The Sky HD box does have many different connections including HDMI, Component, scart & S-Video - see Here for more details.
Mark.
Old 01-07-2008, 12:06 PM   #3
2,333, Level: 11
Re: hdmi to scart
thanks for the answer but the new sky hd box only has scart or hdmi that is my dilemma! Any other ideas would be appreciated .
Old 01-07-2008, 12:22 PM   #4
Assured Advertiser
Joe Fernand's Avatar
36,531, Level: 46
Points: 36,531, Level: 46 Points: 36,531, Level: 46 Points: 36,531, Level: 46
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 205, Got 1,344
Re: hdmi to scart
Hello s4rgyrs6
There is no benefit in externally converting the HDMI Output of SKY HD to Interlaced RGB to work with the SCART Input on your Display when the Source and Display already have RGB enabled SCART Input/Output sockets.
It is possible to Convert and Retain the 'HD' Signal from the SKY HD HDMI Output to work with the YUV (Component) Input on your Display (cost approx 150.00 GBP) - though you need to ensure your Display works with 720p and or 1080i at 50Hz on its YUV (Component) Input.
Joe
Old 01-07-2008, 12:27 PM   #5
Greg's Avatar
38,927, Level: 48
Points: 38,927, Level: 48 Points: 38,927, Level: 48 Points: 38,927, Level: 48
Activity: 63.9%
Activity: 63.9% Activity: 63.9% Activity: 63.9%
Thanks: Gave 178, Got 1,396
Re: hdmi to scart
Is your Plasma HD ready?
Old 01-07-2008, 12:30 PM   #6
Assured Advertiser
36,531, Level: 46
Activity: 20.9%
Re: hdmi to scart
If it was it would include an HDMI Input!
Joe
Old 01-07-2008, 1:54 PM   #7
Bachstrad's Avatar
10,748, Level: 24
Points: 10,748, Level: 24 Points: 10,748, Level: 24 Points: 10,748, Level: 24
Thanks: Gave 1,076, Got 269
Re: hdmi to scart
This is where the problem lies, the new Sky HD box doesn't have connections for component out.
ATB
Max
