Is this HDMI - DVI cable up to the job?
Old 29-06-2008, 8:45 PM   #1
2,148, Level: 10
Points: 2,148, Level: 10 Points: 2,148, Level: 10 Points: 2,148, Level: 10
Thanks: Gave 2, Got 0
So i've been looking around for HDMI to DVI Cables and stumbled across this one.
http://cgi.ebay.co.uk/2M-HDMI-DVI-CA...d=p3286.c0.m14
I will be using it to connect a HP w2207h (HDMI) to my 8800GTX (DVI)
Is this cable suitable?
Thanks.
Old 29-06-2008, 9:29 PM   #2
8,116, Level: 21
Points: 8,116, Level: 21 Points: 8,116, Level: 21 Points: 8,116, Level: 21
Thanks: Gave 25, Got 91
Re: Is this HDMI - DVI cable up to the job?
Providing that youre DVI output can handle DVI-D (I think thats the one... it more than likely will) then at 2m that should be fine. For that price, its not a massive loss if it doesnt!
