HDMI pc to 50" samsung plasma, Cable needed
Old 21-06-2008, 8:00 PM   #1
4,399, Level: 15
Points: 4,399, Level: 15 Points: 4,399, Level: 15 Points: 4,399, Level: 15
Thanks: Gave 45, Got 0
I have purchased this computer:
http://cgi.ebay.co.uk/QUAD-Q6700-PC-...1.c0.m14.l1308
Can anyone recommend me a good hdmi to hdmi cable for it?
thanks.
Old 21-06-2008, 8:08 PM   #2
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Re: HDMI pc to 50" samsung plasma, Cable needed
There is nothing special required, you just need an HDMI cable of a suitable length.
Something from www.ukhdmi.com will be fine as will cables from many other sources.
rude1978 (22-06-2008)
Old 21-06-2008, 8:23 PM   #3
Illustrious Member
Badger0-0's Avatar
43,325, Level: 50
Points: 43,325, Level: 50 Points: 43,325, Level: 50 Points: 43,325, Level: 50
Activity: 84.1%
Activity: 84.1% Activity: 84.1% Activity: 84.1%
Thanks: Gave 467, Got 1,881
Agreed.
Just don't pay too much.
At short distances, even cheapy rubbish will work perfectly fine.
Build quality counts a bit though.
Old 27-06-2008, 2:18 PM   #4
4,399, Level: 15
How about them cheap ones from Asda/Argos etc?
Old 27-06-2008, 6:00 PM   #5
Illustrious Member
Badger0-0's Avatar
43,325, Level: 50
Activity: 84.1%
Perfectly good
And if, on the off chance, they don't work, it's no problem taking it back.
Old 27-06-2008, 7:01 PM   #6
4,399, Level: 15
Got a wharfedale one from argos, 2 new problems
1. The screen is cut of all way around, sides and top and bottom(I think I need to change the screen resolutiom? not sure how though)
2. I have my comp to my surround sound system but only the front 2 speakers are working.
Please please help guys
Old 27-06-2008, 7:50 PM   #7
20,829, Level: 35
If you are using HDMI then make sure the graphics card is sending something like 1080p or 1080i as it is probably using a PC resolution which is causing your problems.
How have you connected the sound from the PC to the amp?
What are you using to test the sound?
Games for example may indeed only output 2 channel sound to the amp but if set correctly a DVD played on the PC could send a 5.1 bitstream out to the amp to be decoded
Old 28-06-2008, 3:22 AM   #8
4,399, Level: 15
I managed to get the screen problem fixed by going into my graphics card settings and selecting an option where you can adjust the display so that it can fit in your screen. I still need to play around with the other screen settings to get a nicer picture.
As for the sound, still problems
I am connecting by optical and coax, but both ways it is only the 2 front speakers working. I have tried dvds. The surround sound is working fine when played on my xbox 360.
The drivers seem to be up to date.
This is the computer I have:
Old 28-06-2008, 8:43 AM   #9
20,829, Level: 35
Your computer is just a collection of standard parts and from the looks of things you don't have a separate sound card so I assume you are using the motherboard chipset.
What software are you using to play the DVDs?
It will need to be something that supports DD/DTS and you'll need to make sure it is enabled as it is usually an option to output the encoded stream.
You haven't mentioned what your 'surround system' is but I assume it does have a DD/DTS decoder?
Old 28-06-2008, 1:53 PM   #10
4,399, Level: 15
I am using windows media player 11.
This is my surround system:
http://www.sony.co.uk/view/ShowProdu...TechnicalSpecs
I have gone to control panel>sounds and audio devices> audio tab>advanced sound playback, and selected 5.1 surround sound speakers.
I also have realtek hd audio manager and have selected 6ch speaker and have clicked the play button to play sounds comming out of the speakers but its only the front two which play.
I havent seen anywhere I can see DD or DTS to select it or enable it.
Old 28-06-2008, 2:35 PM   #11
20,829, Level: 35
Try a different player like VLC - http://www.videolan.org/vlc/ see if that solves your problem.
Are you using Vista btw?
Old 28-06-2008, 9:17 PM   #12
4,399, Level: 15
Getting closer!
Downloaded the player you recomended......
I got the display on my reciever to show all of the speakers and not just the 2front...but the sound is very "choppy" ...?
Old 28-06-2008, 10:00 PM   #13
20,829, Level: 35
It is only a free player but it is known to work hence the suggestion.
You may want to move this over to the PC forum for more advice or you may want to try something like the trial version of PowerDVD as a comparison.
Old 28-06-2008, 10:18 PM   #14
4,399, Level: 15
Thank you very very much
I fixed the sound by selecting "send audio mode to waveout"
Will have a play about and look at powerDVD
Thanks again
