HDMI cable from John Lewis / Other retailers
Old 16-06-2008, 7:23 PM   #1
2,523, Level: 11
Points: 2,523, Level: 11 Points: 2,523, Level: 11 Points: 2,523, Level: 11
Hi guys,
Simple one really, I'll be picking up a new LCD TV from John Lewis this weekend.
If possible, I'd like to buy an HDMI cable at the same time.
I just want a decent quality budget cable, only want to spend £20-£30
I don't have to specifically buy from John Lewis. Around the same area there are Dixons, HMV, Sony Centre, Superfi and Richer Sounds.
I imagine they are all much of a muchness, but if any of you guys know of a particularly decent hdmi cable at that price, available from any of those retailers, I'd really appreciate it if you could give me the heads up.
Many thanks
Old 16-06-2008, 8:18 PM   #2
10,458, Level: 24
Points: 10,458, Level: 24 Points: 10,458, Level: 24 Points: 10,458, Level: 24
Activity: 12.8%
Activity: 12.8% Activity: 12.8% Activity: 12.8%
Thanks: Gave 89, Got 262
Re: HDMI cable from John Lewis / Other retailers
Depends how long you want it.
Home bargains are selling 1.5m cables for £2.99 if you have one close to you.
If you need a longer one then I can recommend this seller on ebay, I have three 10m cables from them and they all work well with a 1080p signal, posts quickly too so should be with you by the weekend.
Unless its being embedded in a wall or something I wouldn't spend much more than this, its not necessary
Old 16-06-2008, 10:43 PM   #3
2,523, Level: 11
Cheers mate, only needs to be short, and isn't going to be embedded in any walls as far as I know!
I'll check that guy out.
Are all HDMI cables 1.3 compliant, or is it a marketing ploy?
Thanks again
