VGA-VGA or VGA-HDMI
Old 13-06-2008, 3:48 PM   #1
2,447, Level: 11
Points: 2,447, Level: 11 Points: 2,447, Level: 11 Points: 2,447, Level: 11
Thanks: Gave 2, Got 0
VGA-VGA or VGA-HDMI
Hi, I am about to buy a new TV, it does have a VGA input but my question is this, which would I get a better/clearer picture from, VGA-VGA or VGA-HDMI?
The TV supports 1080P. Would there be any difference?
Thanks in advance,
Patrick
Old 13-06-2008, 3:50 PM   #2
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Re: VGA-VGA or VGA-HDMI
VGA is an analogue signal, HDMI is digital so you can't go VGA-HDMI without some electronics in the middle.
If your PC doesn't have a DVI-D (or DVI-I) output then stick with VGA.
Old 13-06-2008, 5:45 PM   #3
smashie's Avatar
2,957, Level: 12
Points: 2,957, Level: 12 Points: 2,957, Level: 12 Points: 2,957, Level: 12
Thanks: Gave 38, Got 46
also worth a mention is the fact that not all tvs do 1:1 pixel mapping over dvi/hdmi which will make your desktop look gash, i'd stick with vga mate if i were you. I think you will be pleasantly surprised by the quality of image you get..
btw. what tv are you getting?
