recommend me a cheap 7.5-8 meter hdmi cable
Old 06-06-2008, 10:48 PM   #1
4,699, Level: 16
Points: 4,699, Level: 16 Points: 4,699, Level: 16 Points: 4,699, Level: 16
Thanks: Gave 7, Got 0
Could any of you guys/gals please recommend me a 7.5-8 meter hdmi cable v1.3 1080p compatible. This hdmi cable will connect my projector and av receiver. Please only recommend if you or someone you know has used the product.
Thanks,
Old 07-06-2008, 7:08 AM   #2
3,227, Level: 13
Points: 3,227, Level: 13 Points: 3,227, Level: 13 Points: 3,227, Level: 13
Thanks: Gave 15, Got 28
Re: recommend me a cheap 7.5-8 meter hdmi cable
Hello
When you say cheap does this mean a thin poor quality cable or do you want something that will work... And stay working long term.
I would guess you want an alternative to say a Monster or IXOS which are very pricey, nice to look at but once installed you never see it...
I have used Blue jeans cable several times and recommend them without reservation. I have actulay bought and used one of their DVI to HDMI cables of 6m and it was great , no issues at all.
http://www.bluejeanscable.co.uk/store/dvi/index.htm
I would not go for the cheapest, go for the best quality.
da simster (07-06-2008)
Old 07-06-2008, 11:20 AM   #3
4,699, Level: 16
Sorry for not being clear on this before, but when i say cheap i dont mean cheap in quality but cheap in price. Audimushroom from your recommendations i see for my needs it would cost me £42.30(+ postage) for the BJC Series-1 Belden Bonded-Pair HDMI Cables which is 7.63m/25 ft in length.
Thanks any cheaper recommendations?
Old 07-06-2008, 11:39 AM   #4
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Using the series-1 cable for your length is overkill.
Series 2 will be just fine and is noticeably lower cost.
da simster (08-06-2008)
Old 07-06-2008, 10:53 PM   #5
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Points: 3,397, Level: 13 Points: 3,397, Level: 13 Points: 3,397, Level: 13
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 3, Got 100
HDMI Cables
Premium 7.5m HDMI Cable RRP £ 14.99
Premium 8m HDMI Cable RRP £ 15.99
Free delivery
UKHDMI is an Assured Advertiser.
Cablesson ¦ Octava
HDMI Cable - We won the award of the most active company at CEDIA 08.
Old 08-06-2008, 11:37 AM   #6
4,699, Level: 16
HDMIhead those cables look good quality for a very reasonable price. I'll probably go for the the premium N with the nylon mesh for a couple of quid more, Unless anyone recommends otherwise.
Thanks,
Old 08-06-2008, 2:13 PM   #7
3,753, Level: 14
Points: 3,753, Level: 14 Points: 3,753, Level: 14 Points: 3,753, Level: 14
Thanks: Gave 4, Got 0
Hi guys
I was reading through this thread & wanted to ask a question please.
I have just set up sammy HTZ310 home cinema to sammy 32 inch LCD, used optical cable and HDMI cable. Bought both cables from Ebay for approx. £6 each.
When I play a dvd film on the sammy home cinema and then plug the HDMI cable in I then see on the top left corner of the sammy tv, for 3 seconds, 560p ? Is that that quality of picture I am getting ? Should I not be getting more to 1080p that I have read on other threads ?
Maybe my HDMI was a bit too cheap ?
Would appreciate any assistance.
ecurran1969
Old 08-06-2008, 4:02 PM   #8
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
If you're getting a picture, the cable is working. I would check the HDMI resolution settings on your Samsung H/C system. You'll need to check the manual.
Old 08-06-2008, 4:41 PM   #9
20,829, Level: 35
Just to expand on Dave's comment in case it is still worrying you, your cable is physically unable to affect the resolution that your TV displays.
If you set your equipment to display 1080p then that is what you will get, or you will get no picture at all.
If the TV is displaying 576p then that is standard resolution for a DVD so unless your player is set to upscale then that would be normal.
Check your setting on the player and make sure you have upscaling selected then check again.
Old 11-06-2008, 9:32 PM   #10
4,699, Level: 16
Smile Re: recommend me a cheap 7.5-8 meter hdmi cable
Just bought and received an 8m premium N hdmi cable from ukhdmi (very quick and free delivery). Looks good quality on first impressions will let you know on how it works.
